Zafira 2006 35080 v6. Read, erase and write perfectly for eeprom direct
Enviado desde mi SM-G973F mediante Tapatalk
Ford Transit 2018> RH850 = BAD RESULT!
Changes mileage correctly but after 1 day dash displays X X X X , Thankfully X-tool saves backup eeprom file in software folder, write this back in & all ok.. so I assume it will write back correctly in future, so although it wont adjust mileage down (Or up) it can be used to freeze it as long as you keep the dump! Hopefully there will be a bugfix released soon (Shortly after SMOK releases theirs no doubt!)
On the whole I'm very happy with the tool, about 80% success - Thankfully I haven't needed their 'famous' support or use it on airbags!
mate had the exact same problem with a 2019 ford focus (same rh850) but using the smok it read eepom but the failed to chaNGE MILEAGE so i tryed the new update on my x300 dp plus and it worked great for a hour or so them bam XXXX luckily my smok wrote the eeprom bk and all was forgiven but still would like to find a way to do this without the xxxx
Hmmm, looks like its common with RH850 type clusters then.. golden rule is if its got an RH850 - MAKE A BACK UP READ FIRST!!!, DP no good, Smok no good, X-tool (Or should that be X X X X-Tool) no good - guess that just leaves Carprog to try !!
iv done the transits 2019 with the smok and never had a problem tho its so annoying. my smok is suppose to be able to do the focus too but it just keeps failing
justinJC (13th August, 2019)
x-tool vs range rover evoque 2018 = corrupted file in eeprom
Well at least theres a good solution for doing the Transits with X-tool, get the Smok activation!
I didn't read this tread and ordered x-tool full from x-tool.eu... I see mostly bad comments about them... Paid by bank transfer, still waiting for their tool one week now... He told me there is problem with my address and that package returned to them because that. Told him I can give another address, but no reply since... Is it trusty company to deal with? Should I ask money back and buy from x-tool.org?
only
GSM: +48 662 761 861 - WhatsApp, Viber
E-mail: support@x-tool.org
Skype: x-tool.org
WWW: x-tool.org
please press the little THANKS
Hi all! Can someone write the exact process of doing Volvos with X-tool? I know it depends on model and year. On some cars you have to do CEM, on others DDM/PDM and "block CEM" etc. It will be great if someone will write how to do XC60 2009, 2012, 2014 (digi dash) and what is the difference. Also same question about V60 2010, 2013 and 2014 (digi) and V70 2012 and 2014 (digi). Thanks for help!
lost dongle
I haven't reached them in 3 weeks
X-TOOL HELP
Hello Y110 SOT TRANSİSTÖR
piece is broken what is it exactly
respectsHello Y110 SOT TRANSİSTÖR
respects
Just to keep you updated. I received my tool from x-tool.eu. All is ok. Spoke to Franciszik (I believe was him) on skype, he did send it, but parcel service is a total mess, It could have gone around the world in all this time.
