Page 60 of 114 FirstFirst ... 1050555657585960616263646570110 ... LastLast
Results 886 to 900 of 1700
  1. #886
    Citroen DS3 2011 - Cluster & BSi by OBD - no removal of cluster works 100% ALL by OBD!!
  2. The Following 2 Users Say Thank You to justinJC For This Useful Post:
    aliali18 (29th August, 2019), skens (23rd August, 2019)
  3. #887
    Feb 2015
    GREECE
    hello
    Anyone knows if the x-tool can make correct km's in instrument in Audi A3 mqb 2014 year?
    Thank in advance !!
  4. #888
    Aug 2016
    EURO-KOLCHOZ
    Quote Originally Posted by speedservice View Post
    hello
    Thank in advance !!
    Yes, it can
  5. The Following User Says Thank You to jetronic30 For This Useful Post:
    speedservice (5th September, 2019)
  6. #889
    Is there a solution for transit 2018+ without xxxx?
  7. #890
    aliali18's Avatar
    tunis - (kasserine*Kairouan)
    308 model 2015
    reading and writing bsi ok dash ok and km not change
    what should I do
    thanks digital-kaos
  8. #891
    Feb 2015
    Lincolnshire
    Quote Originally Posted by aliali18 View Post
    308 model 2015
    what should I do
    remove battery and reconnect
    Stop getting worried about what could go wrong, and start getting excited about would could go right!
    hmmmmmmm........eeprom
    Digi v4.94, Xtool, R260, R270, Smok, VagProg DataSmart 3+ Smelecom, Autel Maxisys ms908, SpeedFilters
  9. The Following User Says Thank You to Dayo For This Useful Post:
    aliali18 (6th September, 2019)
  10. #892
    aliali18's Avatar
    Quote Originally Posted by Dayo View Post
    the same problem
    thanks digital-kaos
  11. #893
    Dec 2017
    Quote Originally Posted by nemena View Post
    I don’t use Xtool
    But on other tools I use no issues now all working good now
  12. #894
    Dec 2017
    the same problem
    Try doing Cluster Manually and bsi obd
  13. The Following User Says Thank You to Happy786786 For This Useful Post:
  14. #895
    marina_rv's Avatar
    Ukraine
    308 model 2015
    what should I do
    BSI Valeo UDS OBDII ???
    please press the little THANKS
  15. The Following User Says Thank You to marina_rv For This Useful Post:
  16. #896
    aliali18's Avatar
    Quote Originally Posted by marina_rv View Post
    yes
    reading ok
    Writing ok
    And reading dimension write nothing changes
    thanks digital-kaos
  17. #897
    Mar 2019
    I am confused about X-Tool. I am looking at buying one, but am getting conflicting information.
    Firstly there seems to be 2 websites for X-Tool, both selling for the same price, but both saying they are the original and the other is a copy x-tool.eu and x-tool.org - which is is legit?
    Also there seems to be a lot of Chinese tools called XTool and they are mostly a tablet or handheld based device, which don't look like they're related to this X-Tool - Are these devices related to each other at all?
    Then to further complicate things, I've read people saying X-Tool is the same as carprog and progtool which are very cheap. Is this correct?
    Ultimately if I am looking at buying an X-Tool, where should I be buying it from?
  18. #898
    Feb 2015
    Lincolnshire
    .org is the real xtool site. The eu site is a reseller and hes very rude, so get it from kermol the creator on the .org.
    xtool is a copy of smok i think you will find. Xtool release the same software a few weeks after smok release
  19. The Following User Says Thank You to Dayo For This Useful Post:
    aliali18 (7th September, 2019)
  20. #899
    Aug 2016
    EURO-KOLCHOZ
    you forgot to write that the scammer Smok is a copy of DP4 and others, this is how it looks
  21. The Following User Says Thank You to jetronic30 For This Useful Post:
    Robert dc4 (30th September, 2019)
  22. #900
    autocargo's Avatar
    I can see two new updates on their page ...
    X-Tool v11.05
    ~23.09.2019
    Update
    VW/Skoda Johnson Controls 70F3426+95128
    Skoda Octavia 2013...
    VW Passat 2013...
    VW Golf 7 2013...
    VW Turan 2013...
    - repair odometer
    X-Tool v11.04
    28.08.2019
    Update
    Nissan Qashqai HCS12X by OBDII - repair odometer, read\write Flash, read\write Eeprom
    Nissan Murano HCS12X by OBDII - repair odometer, read\write Flash, read\write Eeprom
    Nissan X-Trial HCS12X by OBDII - repair odometer, read\write Flash, read\write Eeprom
    Nissan NV200 HCS12X by OBDII - repair odometer, read\write Flash, read\write Eeprom
    Nissan Navara HCS12X by OBDII - repair odometer, read\write Flash, read\write Eeprom
    Nissan PathFinder HCS12X by OBDII - repair odomete
