aliali18 (11th November, 2019)
good. someone can help me ? peugeot 308 2015. whenever i change the kilometers i turn off the battery it goes back to the old kilometers. x-tool
hi
you have to change in 2 places, first bsi then instrument panel
regards
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
V11.05.1
VW\Skoda JC 2013... by OBDII - added option read\write Eeprom (not all area possible to write)
Xtool new update 11.05.1
Read/write JC eeprom
Tried today read EE doesnt work sec access error, read km ok, write km not possible km must be under 100?? Prepare obd- sec access error
The update doesnt work, load of BS
Pzolee (20th November, 2019)
Eeprom read by obd is very easy on this car.
Write is the same. But you cannot write the "important " adresses.
So for mileage changing you need a little bit more.
aliali18 (16th November, 2019)
Hello.
When trying to make a 308 (2015) I did not save the memory of bsi and by lapse I loaded the memory of dash in bsi. bsi decoded everything. Then I went to get the backup that x-tool does and restored but then I saw that vin had decrypted and the key too. With the psa machine I returned to put the chassis in the car but it does not turn on because the code of the transponder disappeared. when i try to read the pin it says "~~~~".
How can I now retrieve the pin code to insert manually with the peugeot machine? the error you give me is: coded key.
attached to the bsi backup file.
Unless you corrupt the bsi eeprom it should start, when you write flash must then write eeprom after and car will start
If need to code key and cannot retrieve pin, need to use something like skp900 which can code a lot of PSA keyS without needing pin, only need 1 key to turn ignition
When inserting the stored file and then disconnecting the battery for a few minutes they do not recognize the vin. The car is beeping. and it does not catch. When trying to read the transponder nothing appears. I basically unscheduled the transponder.
You have the option to try read pin using Xtool, you can try SMOK or AVDI or other tools to read pin from BSI and program key with Diagbox, of you cannot retrieve pin you can buy a machine like skp900 that can code without pin or read pin and code key
try ..
0. remove key and wait when bsi go to sleep
1. wakeup by turn on the light (no key)
2. make dash
3. make bsi
4. make dash again
5. turn off battery for minimum 5 minutes
aliali18 (21st November, 2019)
Has anyone had success with cas 2 with a5 cable? I get booting for ages and doesnt do anything, tried v1 and v2
Stop getting worried about what could go wrong, and start getting excited about would could go right!
hmmmmmmm........eeprom
Digi v4.94, Xtool, R260, R270, Smok, VagProg DataSmart 3+ Smelecom, Autel Maxisys ms908, SpeedFilters
