Ppl can help me .
Change km for 0 .
I reas Dash eeprom A2
Now need change hex from 0 km
https://we.tl/t-rnHw0x6rKR
Peugeot 308
2016
Valeo
Km original 159.220
X-tool
Because x-tool no can only obd change km Dash. 93c86
Tnks
Ppl can help me .
Change km for 0 .
Peugeot 308
2016
Valeo
Km original 159.220
X-tool
Tnks
93c60 doesn't exist...i think your eeprom could be a 93c86,
make a new thread, this thread is for questions and answers about xtool, no to change mileage.
It is also important you see this link to get help and press help button when you receive it!!!
https://www.digital-kaos.co.uk/forum...php?f=174&a=32
Stop getting worried about what could go wrong, and start getting excited about would could go right!
hmmmmmmm........eeprom
Digi v4.94, Xtool, R260, R270, Smok, VagProg DataSmart 3+ Smelecom, Autel Maxisys ms908, SpeedFilters
Has anyone managed to dash a peugeot 308 just for obd? already tried in 5 I can only manually doing the dash.
already tried :
1 write dash 2 write bsi 3 I turn off the battery. I can't.
I tried too 1 bsi 2 dash 3 turn off battery anything .
also 1 dash 2 bsi 3 dash 4 battery. nothing.
already tried with and without key.
they were all Eeprom 93c86 there must be a way?
No work full by obd...
308 new shape 2014 goes obd
If older model need to remove clock from car, then write bsi, read again to confirm mileage has changed, change clocks eeprom, if the mileage bounces back to original your not writing the eeprom correctly
This should be an easy job
Peugeot 308 2014+ is full obd mate
Put key in ignition but dont turn on
Change km in dash, change km in bsi, remive battery 5 mins
If doesnt change which sometimes happens with valeo bsi, do it again it will work
When you wrote dash and bsi, before disconnect battery you can read dash and bai and make sure the correct km value has been written
These are instructions from the manufacturer and developer Mr Kermol from Xtool.org
The Instructions seem to work so must be something in it we dont understand
SMOK has option to do BSI valeo and 308 Dash simultaneously so it dont bounce back
Xtool say to do it with key in ignition so both can be corrected without miles bouncing back, as the clock and bsi mileage only sync when ignition is turned on, why the key must be in ignition is anyones guess
