3 differents Dodge Charger 2016, NOT WORKING!!!!!
Problem solved by DP4.
Hi Friends!
I made Passat B8 3G0920751 SW:5310 before one year. Everythings work OK set new mileage OK but after that I get B2000 41 [009] - General checksum failure [Control unit defective (CRC Check ROM)] error codes. So i left but later it turned out that the lane keeping assistant was not working because of it. A colleague solved it with SMOK but I wasn't there I didn't see it. He said make reflash by OBD.
What do you think I will know next with X-Tool? Which step should I repeat? Flash Dash OBDII? Select file or no? Can I make it with new value?
Thanks!
Ds4 2017 bsi valeo uds fail conect.
Ibiza 2017 Mqb séc fail no version
Enviado do meu iPhone usando o Tapatalk
2020 v11.31.1
hi
octavia 2015 dash 5E0920781 eeprom 95128 JC,according to instructions, calibrated km, but after removing the board and returning from power, returned the old km!! v11.44.3
regards
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
Hayssam1 (2nd March, 2023)
hi
no new update for JC! that's the easiest answer, scary !!
regards
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
Memories :
Hello any inf about last update 11.58?
tool does not udate.
Hi friends
I have question is these tool good to buy in these time or there some equivalent better solution in these price range?
Has anyone succeded Daily 2020? I am having some problem with the instrument cluster, Goes to INIT, then communication failure.Any idea ?Needs the resistor between can wires maybe ?
