km666 (15th April, 2015)
technical support, very very very bad
the excellent tool
help there, do not answer mail !!!!
CentralinasPt (18th June, 2015)
Renault Megane II 2007 - Ok by OBD 2 seconds.
After that need to remove dash fuse for 5 sec.
Have in mind that in same fuse is Radio, and radio code will needed after that.
Send code security and I will send to you
88diablo (19th March, 2015)
in those cases i just tell a customer that battery had to be removed in order to complete a job, now you need radio code. find it in your book or go to dealer or pay me some more money to get a code. i'm tired of those dumbasses wanting everything to be fixed for peanuts. same as you go to service to replace battery, should they pay for a code extraction in that case? bullshit! i dont even adjust clock to those
The X-tool software have calculator for code from radio SN in this case.
All full worked manual solutions - FAP/DPF OFF, Adblue/SCR OFF, EGR OFF, TVA OFF, SWIRL OFF, O2/Lambda OFF, DTC OFF and etc
Our database available for download 24/7 on EVC server for all legal WinOLS users
peugeot 407 2004 2.0 hdi 136cv bsi and dash obdii in 2 min, working perfectly.
saving time earn money
Forward javyb.
javyb (21st March, 2015)
Thats why its 2 min job you only did bsi by obd and dash took higher value from bsi...
