If you open Xtool and go to dashboard and select peugeot and dash, it will give you a list of all dash that goes obd and the instructions if doing dash and bsi full obd or bsi obd and dash on bench, instructions are within the software
This is really the problem. I think they sync soon to the bigger kilometers. I have 2 to do tomorrow and I will record a video to show you.
I think if it was done dash and bsi same time as the abrites and smoke would be right way.
Now where can I get access to these x-tool tutorials?
aliali18 (22nd November, 2019)
The vídeo . Disconnect battery 5m And nothing change .
Have anyone tried to do Volvo XC60 2015+ with X-tool?
I have found this video, where is shown how 2013+ Volvo was done with x-tool.
https://www.youtube.com/watch?v=G0tRLytXqFc
But does it work properly on newer models 2015+? Any experience?
should work. but dont to it if car has ACC. because probably will not work anymore after correction.
bukake (24th November, 2019)
Johnson Control Xtool added,anyone test it?
not working
Hahaha,I was hope it will work,fool me.
Opel Meriva 2011 ,dash (BCM) recalibration OK.
Nicolas9 (27th November, 2019)
hi
audi q7 2009 obd ok 40min
dsg -read but not write
regards
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
Ford transit custom 2017 years very good 1 minute obd2.
VW Touareg 2016 good ic out prepare eeprom and OBD2 write km only good.
