Any one guys
Guys i have been experimenting with Galletto 2 after 1 month i get it working (SW issues) but now i can read edc 16 (vw T5 ecu) but i cant write.
I get an error and it does not write at all.
Till now thats what i tested, as it fails i did not test on other cars.
Any idea where do i start with the repair of this unit,
I read the v53 topic ans i see so much different storys,
Pls some help.
Wbr Adam
Any one guys
how u read it ? obd
if obd will not work jut bdm
mine is read write edc16 bdm not work via obd
and edc17 boot mode
honingkoning (24th February, 2015)
Some elements you need to change. Hc245 and hct125
Work is a primitive way to spend Your free time.
F.Kiepski.
A tip for everyone.For edc16u34 vw group when the dashboard use uds protocol then you can read write safe with bdm, with can line you can read write safe with obd.I had a problem in the past and now i have learned my lesson.
I Will try to immo off this one and then tried it again.
I am also experimenting in a vw ecu (pcr2.1) from a 2009 1.6 tdi.
Will this work on the bench or does this need to be fitter in the car die to locked immo.
I know that i need to prepare eep for wrijving this ecu.
Wbr Adam.
You can read and write (after unlocking) PCR on the bench.
