Results 1 to 12 of 12
Hybrid View
    Default Mercedes w204 220cdi Delphi DCM3.2 dead after chiptuning
    Today I do a Mercedes C220CDI 2007 w204 220cdi delphi DCM3.2 ecu. After tuning I drive car for 2 miles. Then I stop car and try to start it again. Car don't crank and nothing light up in car. I have stil have contact With engine, AB and ESP With diagnostic tool. Files looks okey and can read and Write to ECU BDM.
    Have try orginal file also. No faultcode on ecu.
    What can be wrong ?
    MACEDONIA
    Lookin esl
    I can take key out and move steering wheel. that strange...
    MACEDONIA
    U tell that esl operate? lock and unlock steering?
    open all the time not Lock at all
    MACEDONIA
    ESL is problem ... I can repair that
  7. The Following User Says Thank You to whiskymk For This Useful Post:
    kire106ka (20th February, 2015)
    are you sure about that?
    MACEDONIA
    Yes i have repaired many of them with that problem
    Go with stardiagnose in ezs and read errors ,, must be esl locked
  10. #9
    Today aldo can start it drive for 2miles stop and start car okey. Then the same not start and esl not activted and can turn steering wheel.
  11. #10
    MACEDONIA
    after 2miles u stop the car and turn off or car stop itself?
    If u stop, turn off and after don't give ignition then for sure is esl
    In that case will be stoped forever
  12. #11
    I stop car With key. ESL stil open and car not start again. When you turn key it should open and Close ESL also if Engine ECu is dead ?
  13. #12
    smayer's Avatar
    Jan 2012
    No need more search, you have the right answer in post #2. Repair or replace the fuc*** ESL!!
    I have had a bad experience with Fly ....
  14. The Following User Says Thank You to smayer For This Useful Post:
    kire106ka (21st February, 2015)
