Depends on what ecu is in it
bersch8688 (22nd February, 2015)
I dont know
I look Monday with Star Diag
maybe is ME2.8
Try read off 29F400BB-90SE both.
In the case of M137.
regards.
Thanks for info ;-)
If you want I can make you very good tuning on this car. Without problem I can make you 650 hp
Ok
But customer say only OBD read and write
But this car dont read and write obd
what ecu have, if is me2.8 open ecu and red flash.
This ecu have two flash and it can not be read via obd you must desolve a two flash and read it by programer
DPF/FAP off, AdBlue off, EGR off, Throttle valve off, Flaps off, DTCs off, Lambda off,
Also you should made tune on transmision
