Page 1 of 8 123456 ... LastLast
Results 1 to 15 of 108
    Aug 2012
    Default Allison DOC 11.0
    I like to share whit all this ISO of Allison Doc 11.0.
    I hope you find it useful.
    Kind Regards.
    https://www.dropbox.com/s/oa4igefida...1.0.1.iso?dl=0
    If you need help on activation please put here your offline codes.
    Kind Regards.
  2. The Following 13 Users Say Thank You to anih3n For This Useful Post:
    ASTRODODGER (25th March, 2019), brimmstone (7th June, 2015), compconsult (10th April, 2015), DICODIESEL (25th May, 2015), eddie8 (5th January, 2018), gregs007 (26th May, 2015), kitty-hawk (26th April, 2015), oldwest1971 (29th October, 2023), ronyx (10th July, 2015), salimscan (24th April, 2018), sheik (13th May, 2016), thangtn (23rd March, 2016), ult (4th June, 2022)
  3. #2
    Feb 2012
    USA
    Need an passord License Key 28441GADM7D and activation 1XA4JA2YJ5AG3FF9NNC77CMNVHTHQ1 THanks
    Senior Member kitty-hawk's Avatar
    FRANCE
    Quote Originally Posted by joelkenworth View Post
    1545HV5966R7X1JR792AHR4PEEGWWCYQVJ
  5. The Following 2 Users Say Thank You to kitty-hawk For This Useful Post:
    joelkenworth (18th March, 2015), ult (4th June, 2022)
  6. #4
    Ga.
    I have Allison doc 11 it worked good for a couple weeks then said it need to be license,but it won't let me install password. there is no cursor blinking. I have unistalled it 2 times & reinstalled, but it will not delete the old license.what I need to know is what file the license is in or what shall I do. I have worked on this for hrs.but I can't get rid of the old license.Thanks to anyone that has some input on this.
    blackpirate's Avatar
    Jun 2009
    Quote Originally Posted by tyner130 View Post
    hmmm seeems it calls home and deactivating!
    simplest thing, use revo unistaller to unistall it! clan all related files, including registry keys!
    install it without internet connection , activate it and block it by firewall!
    cheers
    If freedom is outlawed, only outlaws will have freedom!!!!
  8. The Following User Says Thank You to blackpirate For This Useful Post:
    tyner130 (20th March, 2015)
  9. #6
    FRANCE
    First use this tool. (Allison Reset)
    AllisonReset.zip
    Then, install Doc V11.0.1 and updates. www.noregon.com/allisondoc/docuniupdate.html
    Run Allison Doc, You will get a activation windows to fill in info, make sure you are not connected to internet!!
    Activates the software.
    After that:
    Open Allison Doc and click on HELP tab then on CONFIGURE INTERNET CONNECTION.
    uncheck IE proxy and use http://www.myproxy.com or what you want...
    Use Port 8888
    Click OK
    Voil????...
  10. The Following 9 Users Say Thank You to kitty-hawk For This Useful Post:
    anwar2010 (19th April, 2015), brimmstone (7th June, 2015), compconsult (13th April, 2015), ferhah (4th November, 2015), gustawos00 (31st March, 2015), mathura (22nd October, 2016), maximus25 (10th May, 2017), rdjorge (25th January, 2016), tyner130 (20th March, 2015)
  11. #7
    Can somebody might help me with activation code for 28441GADM7D 1XA6CG3EWLLYH2FAANYY4D3M937499
    Thx in advance..
  12. #8
    Nov 2012
    Quote Originally Posted by gustawos00 View Post
    Thx in advance..
    1545HV5966R7X1JR78M79CCN38EN7CL79F
  13. The Following 2 Users Say Thank You to Morton03 For This Useful Post:
    gustawos00 (31st March, 2015), kitty-hawk (23rd May, 2015)
  14. #9
    Top Poster compconsult's Avatar
    California, USA
    Can someone please explain how to get the license key to post for a license? I installed and updated per instructions by kitty-hawk but I don't see the license code at all? I filled out the license form with a name and address but still no code. It just asks for a license. Thanks
  15. #10
    FRANCE
    Solution in your PM box.
    Regards,
  16. The Following User Says Thank You to kitty-hawk For This Useful Post:
  17. #11
    California, USA
    Quote Originally Posted by kitty-hawk View Post
    Regards,
    Thank you for your help and for sharing
  18. The Following User Says Thank You to compconsult For This Useful Post:
    kitty-hawk (13th April, 2015)
  19. #12
    hey guys it is work for reprogramming too ?? Can somebody might help me with that.
  20. #13
    California, USA
    Quote Originally Posted by anwar2010 View Post
    Yes I have setup the programming and it appears to work. Although I have not connected it yet to a truck
  21. #14
    thnx friend , for your reply
    i will download it ,
  22. #15
    AllisonReset.zip
    After that:
    Use Port 8888
    Click OK
    Voil????...
    hey i follow ur instruction and i fill the activation window after that i just have two bottoms one "active later" when i press it the software closed and the other " continue " when i press it give to me new window for activation but i don't know how active it .... help plz thnx in advance
