I need remove dtc Code P2563
try this
check pm
Not ok ecu error: ecu reject programming
I need help.How to recover edc17cp14 error Writing Initialization... ERR FILE 014400 - OTP SECTOR NOT WRITEBLE
I have FGTech eu clone.Thanks.
To 3% error Writing Initialization... ERR FILE 014400 - OTP SECTOR NOT WRITEBLE
Infineon Tricore TC1796
CPU-ID=0000182000008A02
Internal Flash ID = 0031C002
Internal Flash 2048Kb Protected
OTP Protect: 0x10000 -- 0x13FFF
OTP Protect: 0x14000 -- 0x17FFF
EXTERNAL FLASH UNKNOW OR NOT PRESENT
EEprom 128Kb Protected
Eeprom chk ok ...In your file "all_EEprom" all checksums are correct.
There is nothing to recalculate.checked by http://ecucalc.com/edc17-med17-eepro...ne-service.htm
27-05-2009
boot mode.rar possible to solve checksum correction
Hi, you have problem with boot mode, read good manuals.
I need help ,boot read
Hi, at first explain corectly what you did from the start
We tested several software DPF EGR and wanted a soft error P2563 canceled and the last one I wrote
WinOLS (VW Passat (egr test+dtc) as (All elements) - 507677).rar (91.2 KB, 1 views) it died
http://www.digital-kaos.co.uk/forums...1&d=1424893654
first try to write in boot mode your file "all_IntFl" from boot mode rar file.
yes write my file but after remove boot pin read ecu data nothing
only ............................................
if you try to write another flash
was a week ago to showroom vw for update software.
be possible to update problem
