Page 1 of 14 12345611 ... LastLast
Results 1 to 15 of 197
    aassfour's Avatar
    May 2013
    kensington
    Default Key Codes location
    hey guys
    i know many like me dont know where to find the key cutting code location for different cars , some is door lock , some on the ignition, some is 5 digits , some is 8 digits , different cars has different codes in different location and some u only find it by OBD tools or by VIN or by dumps.
    if its possible to place here on this thread the location of each code for each car for those who u know and like that we can make a nice database that i m sure will help many many including me
    would be better if we can include picture
    The only place success comes before work is in the dictionary.
  2. The Following 4 Users Say Thank You to aassfour For This Useful Post:
    Alex200124 (6th February, 2022), Gagik1984 (18th June, 2017), MrMike (25th June, 2019), qaf (8th June, 2017)
  3. #2
    aassfour's Avatar
    May 2013
    kensington
    BMW CAS system , it can be extracted from CAS by obd or by DUMP. starts with HA000**** . donno if it can be found anywhere else in car or stamped on a lock or so
  4. The Following 8 Users Say Thank You to aassfour For This Useful Post:
    armpower (27th February, 2015), Automat (27th February, 2015), Cesarec (10th January, 2017), Faraday (27th February, 2015), HeXeN (11th June, 2016), keyantic (19th April, 2015), lion0304 (24th February, 2019), Lukaszz (29th March, 2015)
  5. #3
    ray-ray's Avatar
    Most Acura and honda all locks on car have code stamp last 4.
    most lexus and toyota non transponder passager side door lock. Transponder base system have no lock on passager side, so they move it to the driver side.
    Saab the trunck lock has the code stamp. Non h.s.
    vw beetle driver door lock is stamp
  6. The Following 15 Users Say Thank You to ray-ray For This Useful Post:
    aassfour (26th February, 2015), Alex200124 (6th February, 2022), ancient (27th February, 2015), armpower (27th February, 2015), Automat (27th February, 2015), dekimin (27th February, 2015), ecuspark (28th March, 2015), Faraday (27th February, 2015), giorgioma (23rd December, 2022), igorr (26th February, 2015), instakeys (26th February, 2015), key-maker (26th February, 2015), pe locksmiths (27th February, 2015), Recoder (27th February, 2015), rm23 (26th February, 2015)
  7. #4
    Jul 2013
    Scotland. UK
    Useful thread this...
    Suzuki mostly on door lock too - Drivers side (in UK, passenger if LHD, until like Ray-Ray says only one door lock - then it's on that) always usually stamped near top/side of barrel.
    Classic VW beetle, bus, karmann ghia etc - code on all locks & ignitions. Door locks/handles sometimes need the end cam removing to see code underneath.
    Did a 1997 Celica the other day there, had to loosen 2 bolts inside to release the handle, push outward to reveal barrel, TOY43 code stamped near the top.
    As a rule of thumb, any older Japanese vehicles I get - always worth removing door lock to check for code.
    I'll test what I find in this thread, and post pics of any I find...
  8. The Following 11 Users Say Thank You to instakeys For This Useful Post:
    aassfour (27th February, 2015), armpower (27th February, 2015), Automat (27th February, 2015), ecuspark (28th March, 2015), Faraday (27th February, 2015), Geekey (21st November, 2020), muzikisme (12th November, 2015), obdsystems (24th February, 2017), pe locksmiths (27th February, 2015), Recoder (27th February, 2015), rm23 (26th February, 2015)
  9. #5
    Feb 2014
    Saab 9000 stamped on ignition
    first shim to get out
  10. The Following 8 Users Say Thank You to doolittle For This Useful Post:
    aassfour (27th February, 2015), armpower (27th February, 2015), Automat (27th February, 2015), branci2008 (2nd April, 2015), Faraday (27th February, 2015), instakeys (27th February, 2015), muzikisme (12th November, 2015), Recoder (27th February, 2015)
  11. #6
    armpower's Avatar
    Jun 2009
    Italy
    Fiat cars have stamped the key code on ignition lock.Just remove the ignition lock , the code is stamped on the side of lock.
  12. The Following 8 Users Say Thank You to armpower For This Useful Post:
    aassfour (27th February, 2015), ancient (27th February, 2015), Automat (27th February, 2015), Faraday (27th February, 2015), instakeys (27th February, 2015), pe locksmiths (27th February, 2015), Recoder (27th February, 2015), rm23 (26th February, 2015)
  13. #7
    siyadk's Avatar
    Dec 2012
    Holden commodore needs to get mechanical key code from obd
  14. The Following 4 Users Say Thank You to siyadk For This Useful Post:
    aassfour (27th February, 2015), armpower (27th February, 2015), muzikisme (12th November, 2015), pe locksmiths (27th February, 2015)
  15. #8
    stalonerambo
    Guest
    Question
    Quote Originally Posted by armpower View Post
    sip 22 //;;////
  16. #9
    Jan 2011
    Anybody know where Subaru key code is? 2006 Subaru impreza?
  17. #10
    DK Veteran Automat's Avatar
    Chuichu village, AZ
    Quote Originally Posted by siyadk View Post
    Holden commodore or Cherovelt lumina or caprice needs to get mechanical key code from obd
    Perhaps we all mention instances where you will need a key to turn lock first?
  18. The Following User Says Thank You to Automat For This Useful Post:
    dave11674 (4th March, 2015)
  19. #11
    For Mazda 3 / 2004 i found code inside door near door handle .
  20. The Following 3 Users Say Thank You to ArnautuIonut For This Useful Post:
    aassfour (28th February, 2015), armpower (4th March, 2015), Phase 4 autokey (27th February, 2015)
  21. #12
    aassfour's Avatar
    May 2013
    kensington
    For some benz you can find the code located at plastick trunk lock,
    in this picture the 005 is the code
  22. The Following 16 Users Say Thank You to aassfour For This Useful Post:
    armpower (4th March, 2015), autodigitec (4th March, 2015), canakbas (30th June, 2018), dekimin (28th February, 2015), Fallen (7th October, 2015), instakeys (3rd March, 2015), karanja (21st April, 2015), labusas (28th February, 2015), lion0304 (29th September, 2015), lock-key (30th September, 2015), obdsystems (24th February, 2017), Phase 4 autokey (28th February, 2015), Qpcomma1 (8th April, 2021), Recoder (28th February, 2015), siyadk (2nd March, 2015), Weasel3 (28th January, 2021)
  23. #13
    Default opel corsa
    hi
    1- by dump
    2- obd t-300
  24. The Following 11 Users Say Thank You to key4man For This Useful Post:
    aassfour (28th February, 2015), AIHAM (18th February, 2021), armpower (4th March, 2015), branci2008 (2nd April, 2015), Cesarec (29th September, 2016), Geekey (21st November, 2020), karanja (21st April, 2015), keyantic (19th April, 2015), lion0304 (2nd October, 2015), Phase 4 autokey (28th February, 2015), Recoder (28th February, 2015)
  25. #14
    camelgd's Avatar
    Jan 2011
    South Illinois
    Quote Originally Posted by power44 View Post
    On passenger door lock cylinder.
    One trick I use is to use flexible scope to view door lock cylinder codes, whenever possible. I use this trick on older Mitsubishi eclipse and Chrysler equivalent Sebring(MIT1), also older Ford Probe/ Mazda 626. Sometimes it is easier if you have hand crank windows to lower before putting in scope. Small diameter scopes available for 75-125 USD china suppliers. You don't have to pull panel, so it saves time.
  26. The Following 3 Users Say Thank You to camelgd For This Useful Post:
    instakeys (3rd March, 2015), jodge (23rd July, 2022), Phase 4 autokey (28th February, 2015)
  27. #15
    DK Veteran labusas's Avatar
    Nov 2010
    Hi, What year is this MB lock from? How to interpret code 005 to cuts? can't find it
