Page 11 of 14 FirstFirst ... 67891011121314 LastLast
Results 151 to 165 of 197
  1. #151
    Feb 2017
    UK
    Quote Originally Posted by P&D View Post
    That code only gives this in instacode see photo
    but I think it should be HU83
    Thanks but I checked this as well. Pug Partner has VA2 blade and shoul be ABCDEF code. I have lock stamp and wonder how people determine code from it. It might need different software to calculate this ? I can't use lishi car is far from me I was hoping someone can help as it is easy with other cars to do it.
  2. #152
    Dec 2010
    Nottingham
    thats not the key code , that will be a part number to do with the housing its stamped on , it will be ABCDEF series VA2 and these dont use a key code , they use direct codes reversed , so if the cuts from bow to tip were lets say abcdef then the dealer code would be ****fedcba
    with this lock your options are
    1) use lishi va2 tool to pick and decode , have them send you the lock or travel to it
    2) strip the lock to read the wafers again have them send you the lock or travel to it
    3) buy the key code from the main dealer and hope its not had a lock change
    what you have found is not a key cut code
  3. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    redliner (10th November, 2020)
  4. #153
    Nov 2012
    Default Corolla 2014 all keys lost!
    Good luck for all,
    I have a TOYOTA Corolla year 2014 all keys lost, I removed the cylinder lock from the door, it's well I found the key code (4744), but my condor xc mini plus wno't find all the bitting, I dismantle the cylinder lock and I found only 7 bitting (? 7122753), the first one is missing!
    now i need someone help me to findding the firs bitting to succed with turn the key in ignition!
    The key in silca (VA2TE)
    Thanks in advance
  5. #154
    Quote Originally Posted by khaleddaddi View Post
    Good luck for all,
    Thanks in advance
    hi
    u key cut is 57122753 the missing is 5
  6. The Following 2 Users Say Thank You to key4man For This Useful Post:
    khaleddaddi (21st November, 2020), rokibar (21st November, 2020)
  7. #155
    Nov 2012
    key4man thanks alot for your reply!
  8. #156
    Nov 2012
    Hello everybody. Does anyone know Chevrolet Cruze key code location? Maybe on ignition stamp or door lock or dump? Maybe any key programming tool can read it?
    I dont have Hu100 Lishi so help would be greatly appreciated. Thank you in advance.
  9. #157
    need remove ignition cylinder some time key code is ther if no u need disassembly
  10. #158
    Jun 2013
    HON66
    I had this picked and read.
    But insta did not come up with a result, at that time. When decoding. (Got several "Half reading", not easy to know exactly up or down a bitting).
    So left it for a while.
    Since occupied with other stuff.
    Tried to locate a code.
    Found 7I13, on the door lock
    Did not work at that time.
    Found some time today.
    Now with more research - I found out that the "I" is actually an "L"
    In the series K-L-M.
    So I recon the code is either
    L013
    or
    L713
    If any have some experience with this series, by code.
    I would appreciate some feedback.
    I see now, that this kit would be handy.
    Instead of cutting blades, all day long for testing.
    https://www.aliexpress.com/item/32818901609.html
  11. #159
    Ecuprog31's Avatar
    Mar 2018
    Hon66 ive did one
    i have disassembled lock and read code on wafer and no success
    ive changer ignition with lock
  12. #160
    Jun 2013
    Quote Originally Posted by Ecuprog31 View Post
    Hon66 ive did one
    I also disable the lock, and made a key which turn the door lock. (On this vehicle, but not working on the ignition).
    There is something very strange with those.
    Because standard key delivered, is cut the same on both sides of the key. 2 different cuts.
    But when you take the lock apart.
    And make a key which turns the lock.
    It is 4 different cuts, to make it work.
    It works, did it on a DAT17 earlier.
    Worked out fine.
    Since the car had KeylessGo. AKL car.
    But I know, its not the real solution for this.
    I have no idea, how this is possible.
    But that's how it is.
  13. #161
    lion0304's Avatar
    Oct 2014
    Last week i've used first time Lishi HON66 not for Honda car but Chinese Haval H6.
    The A side is common as Honda end at 5 + 1 but B side only last cut is common (1)
  14. The Following 2 Users Say Thank You to lion0304 For This Useful Post:
    Manta1600 (23rd December, 2021), Weasel3 (29th October, 2021)
  15. #162
    Dec 2018
    Quote Originally Posted by Weasel3 View Post
    Worked out fine.
    I did a Jazz 2008 month ago. I picked and decode this lock. But better is take out the roll pin from the ignition. Its very easy with a 3mm drill from the side. Then use something to push the pin out. The number on the lock was the right one.
    https://www.youtube.com/watch?v=w4btJpnHXFE
  16. The Following User Says Thank You to Alpaholic For This Useful Post:
  17. #163
    Feb 2019
    Nederland
    Anybody know where Citroen Berlingo 2005 key code is?
  18. #164
    rob h's Avatar
    May 2011
    Some have the pin key card.
    It is not written on any lock.
    So use lishi, or order a new key by vin from dealer.
    Quote Originally Posted by duzaven View Post
  19. The Following User Says Thank You to rob h For This Useful Post:
    duzaven (22nd December, 2021)
  20. #165
    UK
    The mechanical key code on PSA cars of this era comes on a paper tag with a barcode above the number. Check the handbook pack incase its been slotted in there.
