Page 13 of 14 FirstFirst ... 3891011121314 LastLast
Results 181 to 195 of 197
  1. #181
    Dec 2010
    Nottingham
    if the wafers are all felt when no tension , then has to be either issue with tool or the keyway and plug are badly worn and the tool is turning under tension and comming out of position , if case then try inserting tool then a shim to hold pick square in correct position when tensioning.
  2. #182
    Jan 2021
    Removed the door lock already. Ive never stripped a lock down before to remove wafers. Is it able to be reassmebledor do i have to order a new lock housing as im guessing the pins have to be drilled out.
  3. #183
    Dec 2010
    Nottingham
    i have already told you how to pick the ignition , so you can decode it or remove it , a member here also posted this video showing exactly how to do this amazing what can be found when you search the forum https://www.youtube.com/watch?v=S5eY...gqgz0uanT0yzhg
  4. #184
    Feb 2020
    Russia
    IMG_20210830_012836.jpgmazda 3 2008,code. driver's door, on the larva. the lock can not be removed.
  5. #185
    Dec 2021
    Tunisia
    hi all
    i need help vw Caddy 2016 all key lost
    Is there someone who can show me where to find the key cut code.
    i don't have lishi
    thank you in advanced
  6. #186
    Dec 2010
    Nottingham
    no key cut codes stamped anywhere on vag group , so you really do need that lishi tool if you want to get the key cuts.
  7. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    JHDSoft (22nd June, 2022)
  8. #187
    Dec 2021
    Tunisia
    Quote Originally Posted by rapidlocksmiths View Post
    Even in the eeprom immo or ecu ?
  9. #188
    Dec 2010
    Nottingham
    not even in the eeprom , immo and ecu , you will need lishi or a very friendly dealer to provide key cut code
  10. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
  11. #189
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by JHDSoft View Post
    Call an auto-locksmith
    Solidarity with Ukraine
  12. #190
    Dec 2010
    Nottingham
    Quote Originally Posted by fred77 View Post
    now that is sound advice
  13. #191
    Jul 2016
    Lebanon
    Hi can folks can anyone help me generate the last two digits for this 2012 nissan versa 3 1 2 1 2 4 4 2 _ _. Thanks
    Sent from my SM-A125F using Tapatalk
  14. #192
    Jul 2016
    Lebanon
    Sry this re from driver door lock.
  15. #193
    Dec 2010
    Nottingham
    Ok , if these are the cuts from the drivers door lock then they are positions 3 to 10 and not 1 to 8 , so you need the 1st 2 cuts and not the last 2 cuts .
    if the cuts in positions 3 to 10 are ??31212442 then its narrows down to 1 of 3 keys and will be either
    1231212442
    2331212442
    3231212442
    so cut with 12 in first 2 positions , if no joy then cut same blade 23 in first 2 positions , if no joy then use new blade and cut 3231212442
  16. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    skilion290 (27th October, 2022)
  17. #194
    Jul 2016
    Lebanon
    First ten bitting worked perfect,and I got to learn something new.thanks very much.
  18. #195
    Dec 2010
    Nottingham
    no problem , glad it worked out
