Results 1 to 4 of 4
    Top Poster nicolas2015's Avatar
    Feb 2015
    somewhere in cornwall
    Default Passat 97 1.9 tdi dashboard problem
    I have an vw passat 1997 with a problem in the dash, on diagnosis no fault codes, but the problem stil present, i atached a photo to see this problem. The only fault code that i find is this from photo 2, i can erase him.Any sugestions, thanks in advance.
    drewdom's Avatar
    Aug 2010
    58?59'13.1"N 6?11'19.4"E
    Interlnal memory need to reprogam.Looks like You need new dump for this dash.
    Please dear members push the button if my work was helpfull!
    And reputation button(star)
  3. The Following User Says Thank You to drewdom For This Useful Post:
    nicolas2015 (28th February, 2015)
    Feb 2015
    Quote Originally Posted by drewdom View Post
    If this is the problem with what tool can i read /write the dump, what type of memory needs to be read from dashboard . I have carprog 4.01, tachoo pro 2008, digiprog 3, vagdashcan 5.29, vag-com. With tachoo pro 2008 and digiprog 3 for the moment i can't connect to computer. Any advice, thanks in advance.
    If anyone has a dump for this type of dasboard, 1.9 TDI passat 1997 with green lights.
    drewdom's Avatar
    Aug 2010
    You heave internal error in engine ecu on your photo.Enyway,what is nr of dashboard?
