Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 48
  1. #16
    Jul 2014
    I can open it. here is the file in zip try now
  2. The Following 8 Users Say Thank You to auto80 For This Useful Post:
    AYD (25th September, 2015), groove (15th September, 2018), gvdn (10th January, 2019), luis12 (15th March, 2015), mcode (6th April, 2015), pakrat (10th February, 2022), repairmymodule (14th March, 2015), sherzot (26th March, 2017)
  3. #17
    repairmymodule's Avatar
    Aug 2014
    USA, Earth, Milky Way Galaxy, Universe, Unknown
    Quote Originally Posted by fxshaw View Post
    Actually I just check it out...cant open it so that makes 3
    What program are you using?
    I have downloaded and programmed to a module and it works fine, so have other members.
    I use winrar on my PC and with a generic unrar program on my android, no problem, strange
  4. #18
    Jul 2014
    I try with winrar and winzip and no problem to open with both
  5. #19
    sensadeg's Avatar
    Jun 2011
    england
    WORKS ON 2014 SENTRA! THANKS
    If it was easy, everybody would be doing it.
  6. The Following User Says Thank You to sensadeg For This Useful Post:
  7. #20
    FxShaw's Avatar
    Nov 2013
    Outta This World
    I use 7zip, does it all and light weight. Auto80 re-upload is good to go for ppl who couldn't open it before.
  8. #21
    Jun 2012
    ONT. CANADA
    Thanks for the file.
  9. #22
    luis12's Avatar
    Jan 2011
    Panama
    Now unzip ok, thanks, why the first file couldnt be opened and gives message corrupted or empty file? thanks for share.Thanks Repairmymodule for the file.
  10. #23
    i would like know how did you read xc2336b 2014 nissan sentra airbag module i have xprog V5.45
    please if you can help me
    thnks
  11. #24
    Canada
    you need latest original update from carprog
    If i helped you please press thanx
  12. #25
    Aug 2014
    Re-uploaded file on the first post since it was showing corrupt under 7-Zip for some of you guys.
    Also, I have recently tested this file on 2015 Altimas as well, not sure of the part #, programmed OBD, too lazy to peek at the module...but it works
  13. The Following 2 Users Say Thank You to repairmymodule For This Useful Post:
    ctype02 (30th April, 2015), ODBlue (26th March, 2016)
  14. #26
    Jul 2015
    Thanks. It worked on 2015 Altima
  15. The Following User Says Thank You to Bkjauto2010 For This Useful Post:
    repairmymodule (17th August, 2015)
  16. #27
    rrador's Avatar
    Feb 2011
    Tamo daleko
    Also tested on 2015 sentra 98820-4AT0A and itworks
  17. #28
    Feb 2013
    Tested 28556-3RR0A Sentra 2013 error B1416 control unit
  18. #29
    USA
    It didnt work on 13 Altima and 14 sentra , it was giving lot of codes, it's weird how it works on some and some it doesn't , so far work on 14-15 Altima tested, had no luck with sentra
  19. #30
    i have a 2014 Altima. don't have the car here. Using ETl what flash sector does the virgin dump go into. after that any calibration Of OPDS required or code clearing?
    tnx
