Results 1 to 2 of 2
    Jun 2013
    Default Mercedes initial startups of replaced control units
    Some control units when replaced require initial startup once fitted, by using a Xentry DAS computer. I have noticed some require software updates to the control unit, downloaded from online servers also, before you can carry on with the basic coding and initial startup. Is there a way to bypass this on the original dealer systems, or can this only be done on an offline/cracked system?
    Can we bypass the whole check and update for new software thing? Or it has to be done as part of initial startup?
    some modules comes with out software (only boot loader). Soft needs to be downloaded to spec / variant (SA codes) & unit needs to be programmed.
    Than SCN coding.
  3. The Following 2 Users Say Thank You to wwwiciu For This Useful Post:
    antonypaul (10th March, 2015), smuggler86 (9th March, 2015)
