Can someone calculate also for me immo data from this EDC17C46?
Kind regards.
Kind regards.
Work is a primitive way to spend Your free time.
F.Kiepski.
here , enjoy !
you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
antonypaul (1st June, 2015), maruti (12th July, 2015), meteor80 (1st June, 2015)
Hello, i?m new here and i need help.
Can someone give me the immodata off this EDC File?
Greetings and big thanks
Josefhb
JosefHB (11th December, 2016)
Thank you very much!
Can someone check this immodata and post?
Maybe you want to know: I broke an ECU of a 3.0 tdi and a friend have an ecu from a 2.7 TDI edc17cp14.
Then my friend write to the 2.7 tdi ecu the backup from the 3.0 tdi it works but only with immo off and in the instrumentcluster stay SAVE.
At the Moment i dont know, is there the CS, Pin etc. of the 2.7tdi or there are the data from the backup 3.0 tdi.
Is there a chance to adapt the 2.7dti ecu to the 3.0 tdi engine?
Greeting josefhb 2.7tdi with backup of 3.0 tdi.rar
VIN: 00000000000000000
CS: 60258DCD968616
MAC: 0FD8F3E4
PIN: 01585
ECU: EDC17CP14
Thanks![]()
I check ot tomorrow and replay
Josefhb
Gesendet von meinem SM-G900F mit Tapatalk
if they have same moterboard.... and you have kess.... on bench you can copy entire content off old ecu.....if car is audi may have component protection..... only online vag vas or original abritus....
This 2.7 with backup does not give any proper data as the eeprom can't be decoded. It's a real frankenstein ecu.
This is from your 3.0 backup to 2.7:
IMMO Version 4
TPROT_V07.00.00/1796
CS: 60258DCD968616 (can't be correct as OTP can't be transferred)
MAC: 0FD8F3E4 (can't be correct as OTP can't be transferred)
PIN: 01585 (can't be correct as OTP can't be transferred)
This is from your untouched Backup and is all ok:
IMMO Version 4
TPROT_V02.00.00
CS: CAEFA07D95DF00
MAC: 79BE61CC
PIN: 20400
It should be possible to transfer this to your new ecu.
eltiobarbas (13th December, 2016)
You are welcome.
bonjour
je dois immodata pour cette Ecu pCR2.1
hi mates,
please can some one calculate immo datas from this file, it's edec17cp14 from tiguan
ricards99 (21st January, 2017)
