Results 1 to 14 of 14
    Mar 2013
    Default pcr2.1 kessv2 pdf
    Hy dk mebers
    Anyone have pcr2.1 pdf manual connections for Kess v2 1.89?
    thank you very much
    Here Do not use any other method than this one!
    kess alo had a older one which damaged a lot of these ecus
    ENU_MO_0352.rar
  3. The Following 5 Users Say Thank You to ominimicu For This Useful Post:
    antonypaul (4th March, 2015), garagetech (5th March, 2015), lucim12 (4th March, 2015), martinracing (18th May, 2020), overs0ull (4th March, 2015)
    Mar 2013
    thank you!
    here is my version
    am I ok?
    Mar 2013
    I belive that version of kess was not v2
    anyways I am also going to read it with fgtech v54 just for safety..
    i ment earlier version on the instruction manual, not of kess
    Junior Member MiH's Avatar
    Slovakia
    2 ominimicu :
    This method can damage ECU too (unfortunately tested by yourself ). Especially the one manufactured after 2.2014.
    but i have never damaged a pcr2.1
    Mar 2013
    back with reports
    kess read it by obd ok, but at the end it gave a checksum error message, but the file was ok...
    I put it on bench, did everything exactly as in manual checked everthing but it said no connection..
    I did it with fgtech in the end..
  10. #9
    check your fgtech tricore cable some have 2 wires inverted compared to original pinout
  11. #10
    Mar 2013
    it worked well as it was...
  12. #11
    Mar 2013
    since v1.89 software is old and many boot mode manuals are missing....
    can i use newer versions on this HW or will it block NXp?
  13. #12
    use up to k suite 2.06. of course internet always disabled
  14. #13
    Mar 2013
    thx omi, but some reported many errors after using newer version..
    is there any need for sd card files too ?
  15. #14
    no, no need.
