Results 1 to 15 of 16
    Jun 2013
    Default Technomate TM Twin OE Recording Problem
    Technomate Tm Twin Oe
    Open Pli 4D
    External USB Toshiba Recording.
    About half of my recordings are failing lately.
    When I go to watch what I have recorded, all I get is a blank screen with the programme name on it.
    A few months ago I had to factory reset the receiver as my channels stopped working.
    I got it going again with DCC & add ons, but I can't seem to get Coolman Guide going.
    I sent it to the receiver & I can find it, but not in the plugins.
    I pressed ok to highlight it it & then install it, but it still does not appear in my plugins, even after a restart.
    I wonder if the failed recordings are because of the fact that they are not set through Coolman.
    Also, I can't update Rats Plugin.
    My last successful update was on December 14th 2014.
    But it's the failed recordings that are bothering me most as I have plenty of speed.
    Hoping I can get help for this.
    Sep 2008
    due to forum rules i could guide you but cant say exactly what maybe the issue,multisat tuners use 1,38 or 2.3.0. you should know what they are.
    with image been old is it still supported?
    two feeds both setup for 28.2 and both tuners rechecked for bad connection?.
    do you have setup epg for usb and recordings to hdd as i would recheck your mounts in set up mounts as mine got changed to epg to hdd and recordings to 8gb usb.
    there comes a time when you need to advance your image if you get problems.
  3. The Following User Says Thank You to cactikid For This Useful Post:
    erinville (4th March, 2015)
    Jun 2013
    Thanks for that.
    All the set up is as you said.
    I suspect the mount for the HDD.
    I'll delete the old mount & install a new one tomorrow.
    Sep 2008
    if your toshiba is mains powered hopefuly it is ,make sure it says MOUNT/media/hdd and type ext4 R/W in your mount manager.
    Jun 2013
    It is mains powered.
    It's mounted to media/USB when it should be mounted to Toshiba 3.5 HDD.
    I'm at a loss as to how to unmount the Toshiba.
    Can I do this through DCC?
    If so, I wonder what steps I would need to take.
    Sep 2008
    set up mounts green button should allow you to change it,or delete your mount and remount it all by remote control.
    network-mounts setup. if you have usb for epg make sure in mounts its labelled correctly,and tosh says hdd.
    Jun 2013
    Unfortunately nothing happens when I press any of the coloured buttons.
    Well, blue brings up a list, but nothing there to do with HDD or mounts.
    Sep 2008
    try network?
  10. #9
    Jun 2013
    Tried that & I have a choice between Add new network mount & Mountpoints management.
    Not sure what to do.
  11. #10
    Sep 2008
    adding a new network mount is if you had another enigma2 box in building it could talk to it by network.
    mountpoints management seems to be it for setting up mounts as you want the hdd mounted and set to ext3-4.
  12. #11
    Jun 2013
    Absolutely nothing in there I'm afraid.
    I sent TS Panel to my receiver via DCC.
    I then went into Device Manager & Toshiba 3.5 HDD comes up, but when I try to mount that, is says fixed.
    Then I restarted the receiver & pressed record & it says no HDD mounted or Initialised.
    Strange enough as it does come up in the Device Manager.
    I also formatted the HDD with my PC using EaseUs Partition & formatted it from EXT3 to 4.
  13. #12
    Jun 2013
    Add new network point says
    Active Disable
    Local sharename Sharename
    Mount type NFS share
    Server IP 192.168.0.0
    Server share /export/hdd
    use as HDD replacement no
    Mount options ny,nolock/soft
  14. #13
    Sep 2008
    HDD mounted or Initialised. anything in storage devices as it needs to be initialised first then ext3-ext4.
    add new network point is for finding another box on your lan network only so no need for that yet.
    box has to setup hdd via settings.
  15. #14
    Jun 2013
    Success.
    I found this in another forum.
    I did this through DCC.
    edit /etc/fstab and add this line at the bottom then reboot
    /dev/sda1 /media/hdd auto defaults 0 0
    My only problem now is that I have no Rats Bouquets.
    Would you have an IPK link for this?
  16. #15
    digicon's Avatar
    Just to let you Know Rats bouquets is no more he stopped supporting it just over a month ago, Use ABM instead (Autobouquet maker)
  17. The Following User Says Thank You to digicon For This Useful Post:
    erinville (9th March, 2015)
