Results 1 to 15 of 25
    aslamaslam's Avatar
    Feb 2012
    FRANCE
    Thumbs up BMW delete errors
    hi to all
    bmw 2004 e46 n42
    BOSCH BMW 318.rardme 7531848
    need to delete this error please
    -2A61
    -2A5B
    -2EF5
    -2C9C
    BEST REGARDSSSSSSSSSSSSSSS
    Dec 2013
    help yourself
  3. The Following User Says Thank You to gitko For This Useful Post:
    aslamaslam (8th March, 2015)
    aslamaslam's Avatar
    Feb 2012
    FRANCE
    the same problem?????????????????????
    Babos's Avatar
    Mar 2012
    In dashboard is ON LAMP or only dtc in diagnostic?
    Dec 2013
    dtc should be only in memory,shouldn't have limp
    aslamaslam's Avatar
    Feb 2012
    FRANCE
    Default hi
    hi
    my problem the light transmision code 146
    i change the air mass for 5 times no use the problem isnot solved
    i check all wires and mechanic transmistion every thing is ok
    i noticed that the check engin lamp isnot light at all i think the lamp is not good so i checed it with the lanch with the dash the lamp is ok but it doesnt light with the car
    may be the ecu need new software ?
    ERROR.rar
    i want to delete code error 2D0F hot mss sensor signai
    Dec 2013
    pass is the same
    aslamaslam's Avatar
    Feb 2012
    FRANCE
    Default hi
    gilko
    thank you for you
    but the same problem
    i neeeeeeeeeeeeeeeeed to delete code error 2D0F hot mss sensor signal
    best regards
  10. #9
    Jun 2013
    EU
    hmmm, someone is playing "novice games" with someone else's car...
  11. #10
    aslamaslam's Avatar
    Feb 2012
    FRANCE
    to my friend morgano
    thank you
    Is your last comment ?????????????
    Do you have a solution??????????
  12. #11
    Jun 2013
    EU
    My comment ... seems you didn't like Then i shut up.
  13. #12
    BrunoPT's Avatar
    Oct 2011
    PT
    You have a P code?
  14. #13
    aslamaslam's Avatar
    Feb 2012
    FRANCE
    no (P) code
  15. #14
    Vasily.U's Avatar
    Belarus Minsk
    If the car is automatic transmission GM, it can not work without the proper flowmeter. Check intake manifold for leaks, cats, etc.
  16. #15
    aslamaslam's Avatar
    Feb 2012
    FRANCE
    ok
    can you delete this error and test with car?
