Results 1 to 2 of 2
    Top Poster manutd4life's Avatar
    Default XBMC problem on Duo2
    I have BH 2.1.5 on my Duo2. Now XBMC seems to work on a fresh flash. But when i set the box up fully XBMC stops loading. I narrowed it down to TS Panel, so i put Cccam 2.2.1 on manually. Now as soon as i did, XBMC wont load again. Anyone got any ideas?
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Reflash box load your stuff ie files, lists etc on box reboot check all works make a full image back up. Then setup xbmc try it reboot it and go from there. Although the xbmc add on is good it still has a way to go. Could be vu still has work to do on drivers? hth
  3. The Following User Says Thank You to DOUGALMCD For This Useful Post:
    beatboxbob (28th July, 2015)
