Zgemma H1 OpenATV 4.2 Backup Image
  • digicon
    • 8261
    As Title Backup image for the H1
    Installed:
    Crossepg set for 28.2? east and Cable ( will need either USB stick or External hard drive )
    Openatv mispel_feed for downloading Softcams from the Plugin menu
    BlueHD skin ( $ly skin )
    RedHD Skin ( Virmin Skin )
    ABM setup to scan both 28.2? east and Cable ( you will need to change the Regional code for the 28.2? east and also change the Net ID and frequency for your own area )
    Just a basic setup to get you started all tested and working
    https://mega.nz/#!so4HRLzb!YPDRYqNP_sxN0AA_ppbdu9vfw8G04PRbk1P5Cigi0hY
  • ellesmere11
    • 109
    thanks for the backup, i have installed the image and installed hdd and set internal flash to hdd in epg but when i go to epg its not filled in for the week for both sat and cable i have pressed crossepg downloader and a box comes on at the botom of the screen for about 5 sec then goes off and returns to the plugin menu am i doing somthing wrong.
    • digicon
      • 8261
      Did you reboot the Box after you mounted the HDD what i mean by this did you mount the drive in the Mounts setup section accessed by pressing the blue button, This will ask you to reboot the box as you have a new drive mounted then goto crossepg and swap internal for your HDD
      • ellesmere11
        • 109
        i reflashed your image and mounted hdd and put internal flash to hdd in epg and then went to cross epg downloader and pressed that and again window apears at botom of screen and stays on for 5 sec then goes back to plugin menu no 7 day epg for sat or cable.
        • digicon
          • 8261
          Go to your mounted hard drive via FTP which is normally located in the /media folder and delete both the Crossepg folder and the epg.dat if there is one there and then reboot and try again
          • ellesmere11
            • 109
            no did not work would not load sly info only vm info, so put vix patched back on and worked first time with cross epg and opentv sly uk probider still dont know why it wont load sly epg.
            • hfxlad
              • Feb 2014
              • 91
              thanks for the backup digicon i have hsd this box a few week now but have not ad the
              chance to play about with it untill now.so i have flashed your image and im haveing a few problems on the virmin side
              1. i have changed the ares for my sky that seems fine
              2.changed the area for my virmin but how do i find my frequency as it is showing just 3 numbers in the manual scan?
              3.also the skins are the same colour ie blue for all can this be changed as u say blue and red.
              iv no experience on the virmin side but i have been haveing a search on DK but a bit bit lost pal.
              • digicon
                • 8261
                As you have changed the Autobouquets for your 28.2? east connection you also need to do exactly the same for your Cable connection.
                You need your Net ID and Scanning frequency, thiese need to be entered in the auotbouquets section and also in the main service searching section under the DVB-C tuner part
                • dixie74
                  • Feb 2011
                  • 222
                  Thanks for this Digicon,Had a nighmare setting these up with normal images with your backup image and instruction's all seems good now,with the official images i kept getting the remote unresponsive seems all ok for now finger's crossed.
                  • makster1978
                    • 118
                    how do I change from blue skin to red skin on this image please
