Results 1 to 4 of 4
    rtvservis's Avatar
    Default Renualt Scenic 2007 2.0 nead wirgi ecu filr
    demage eprom oon ecu 0 281 013 507
    Num. HW: 1037382408
    Num. SW: 1037382408
    i cunat program ecu injector and oder parametar.
    i can macke wirgin if sombady have god eprom from oder ecu
    rtvservis's Avatar
    this is read dump bay fgtec inector code . i think it can read full eprom . if i read eprom bay bdm and doo wirgin itt wel repair dump or not . i nead hellp
    rtvservis's Avatar
    edc16cp33
    car working bat i cunot code ijector
    tray vith clip bosch kts . wrth auto com.
    rtvservis's Avatar
    solwed
    problem with the coding inector . the car has lost data from nozzles during regeneration fap filter . launched by regeneration can clip and not passed . when I washed my fap filter and committed regeneration, which is this time successful. LEFT 1 fault / coding ijector / . I've read the codes from injector of the car . coding failed .i tray various combination and spend two days for solution . until i didnt fined on the net this cobination on ijectors DITCHWH CAISFWI ASILAAH A1SF8WG .
    maybi somwon hellp
