sal!
to remedy a start error sprinter with bosch A612 153 16 79 5P08C3 and immo box Temic 026 545 17 32 HC08 0J66D, what fille must read??
THX.!!
sal!
THX.!!
eeprom ecu immo
ionuty (14th March, 2015)
Both memory's.
ionuty (15th March, 2015)
I resolved with "StartERROR" v1.3 . I desolder onliy eeprom ecu and repair with Unlock ECU Sprinter SP08c3 V1, unlock ECU after inserted ecu into car herself automatic coding..
THX!!!
so i must read both hc08 and 5P08C3 and repaired vith StartError v1.3....?? not really understand this part- "Check with sds and lock in, it won't let you "
can you please be more explicit ???
Please..
THX!!
People change, bro..
Check with Star Diagnosis System and marry the Ecu to the wsp, personalisation will fail because there is a data fault in wsp also.
Mark
car startedfirst after we fixed the ecu eeprom ....
its possible to reappear after battery disconnect ????
MBStar not have...
with StartError v1.3 and repair both memory it"s no good???
THX MARK!!
you did not fix ecu problem, you simply told the ecu it was new and in automatic coding mode, It will link for 20-40 starts then cannot self code to the wsp.
Read 0D66J and ECU and use program to adjust files. Will sort problem 100% - Make sure you read Key and make sure it is in the Key programmed box on program as it may have lost transponder code
Thx Mark... i will try.. Thx again..
