is this what you need ?
but i suggest to you dont wast your time with wiring diagram ,,,replace junction box
Need wiring diagram for hyundai ix35 tucson 2011 year,2.0i gasoline,manual transmision.I have problem with indicator lights on drivers side(rear and on drivers mirror),all time is on .When lock vehicle,that two indicators stay enabled and can't turn off.
If someone have GDS instaled, to make some images of indicator light wiring diagrams.
Thanx!
Actions speak louder than words
123cocorico (9th April, 2019), anyerzonmono (1st October, 2019), kelekele (16th March, 2015), stanislav georgiev (17th March, 2015)
That 's right wiring diagram,thanx man.Is it possible to get complete wiring started from turn switch ?
I think problem is not in junction fuse box,this car have another electronic module for flasher lights and maybee is damaged bcm.
It's difficult now but I'll try for you
attachment above edited
kelekele (17th March, 2015)
This diagrams help me so much.Big thanx man!
if you found the solution please let me know , here many cars with same problem and am really not have a time to digging wiring in the car .but some customers replaced junction box at the dealer and it's ok
If possible to found problem,i tell you what is damaged.Junction fuse box is not problem definitely.
To this box on connector i/p F,on pin number 4,comes white wire with constant 12 volt supply.When i cut this wire,left rear and left mirror flasher turn off.Can you please check from where comes that wire,from what module?On photos that you posted i see that from bcm comes only can bus wires,not voltage wires.BCM is too dificult to remove and i think some other module choose problem with rear flashers.
Where did u see i/p F ?
Connector marked F on junction fuse box.To this connector on pin 4 comes white wire with constantly 12v supply and choose to RL flasher and mirror flasher stay allways on and front left not working.When i cut this wire,left front flasher start working normaly but rear left and left mirror stop working.Problem is in that wire but i dont know from where comes.Need to know from what module that wire comes.
Now downloading GDS but is too big.Sorry for disturbing,but without schematic im totaly blind.
Thanx man for help but i must wait to download GDS .I know where is BCM but need data for pin 4 from F connector on fuse box.I must to know where white wire from that pin goes.Must to check everything before remove dash panel and remove BCM module beacuse is too dificult remove them.
1- it's no problem to help you while you downloading GDS.
2- in photos attached in first post , where you see this F connector can you tag it .
3-i didn't post bcm location to tell you where is it ,,i post it to see where is M13-A connector wich including pin 4 from bcm to turn signal switch LH as i understood you .
I give up.I called the customer to take the car and drive him to an authorized service center.
Almost two days i spend to find where is problem.I'm good in reading service manuals and schematic but
without propper schematis i'm totaly blind.
For you big thanx and i help you too everytime you need.
Here is marked pin 4 from F connector on fuse junction box.
Pin marking.rar
Andy Markson (29th October, 2021)
So you need this photo pin 8 in grey connector .
Am sure 99% problem with junction box ,, i hope you can get answer from customer.
Here this problem appear when someone try to install somthing to the car like xenon, camera ...etc .
Best regards
