Results 1 to 2 of 2
    Default Eurovox no signal
    Hi Guys and Gals.
    Since last tuesday my urovox max v started getting a poor signal on most channels and no signal on the rest ( BBC1,2 channel 3 and 4, sky sports and many more). I have 2 boxes up an down stairs and they are both the same. The connection come direct from the vm box outside ( which has 2 seperate feeds for the eurovoxes and 1 fr the broadband)and direct to the eurovox's and internet. I have re scanned, power scanned, and reinstalled factory settings but still no joy. I have brought a signal booster, which increass the signal from 80 to 85% but the signal still keeps dropping down to nil every couple of seconds. I cant see a problem with cables as nothing has been touched. I have tried box at different address ad works fine. The VM box also works fine at my address. I have also downloaded the 8% fix last night but still the same.
    Not sure what else to try. Does ayone have any ideas. Will th latest filmware Eurovox Max+V Kuro v3 Final 18042008 make any difference to te signal problem.
    i loaded ( ufl max v autosort 5-12-08. cleared data and chose 6952 (my area) the signal was 8% red, went back to main menu, tv setup and turned on signal booster(save an exit) .in installation selected fast install the signal was still 8% red . still in fast install i changed the symbal rate to 6887.. pressed ok and got 84% green , instead of scanning i exited out to fast install again changed back to 6952 and the signal stayed at 84% green pressed ok and scanned for channels , bingo i've got a working box again . i hope this may be of help to somebody the way i was helped here ...... thanx to all ... yeehah !!! ............... hope this helps mate
