Results 1 to 15 of 18
    solitaire's Avatar
    LT, jonava
    Default Kawasaki Z1000 lost all keys
    Kawasaki Z1000, DENSO 21175-0097 93c66 - lost keys.
    I add with TANGO key, 1 place.
    but immo blinking, bike not start.
    I try add EH2 emulator 2, 3 place - no result.
    damps before and with key and key data atached.
    please help solve problem
    thanks!
    kawasaki_key_0097.rar
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    original dump good with tmpro
    Top Poster Jeanhdo's Avatar
    Brasil-S?o Paulo
    Your file is correct. Try using a 4D transponder 60. I keys to a Kawasaki Z750 this week with Tango, and it worked perfectly.
    solitaire's Avatar
    LT, jonava
    I added with TANGO 4d60 - 1key, but immo flashing.
    Bike not start, maybe need add to 2 or 3 place?
    solitaire's Avatar
    LT, jonava
    maybe somebody have good file?
    Oct 2010
    You need to add a key as a slave 1 key is a master key
    solitaire's Avatar
    LT, jonava
    I tried add 2 and 3 keys, 1 - left original, no result.
    Oct 2010
    Maybe it's a problem with the bike for ex immo coil on ignition switch
    key-maker's Avatar
    Try to put the transponder chip beside the coil
    solitaire's Avatar
    LT, jonava
    thanks for answers, tomorrow I will try make diagnostic.
    solitaire's Avatar
    LT, jonava
    Service Code 36 - Blank Key Detection
    •This code appears in the following conditions.
    ○The transponder [A] in the master and/or user key is malfunction.
    ○When the spare key of unregistration is used.
    ○When the master key is registered in the registered ECU.
    •Therefore, the service code 36 will disappear when the above issue is solved
    maybe someone have 100% good file?
    thanks!
    May 2011
    How yousolved the problem?
  13. #13
    Croatia
    Hello, have you solve this? I have the same problem...
  14. #14
    Nov 2012
    hello please help immobiliser kawasaki z1000 2007 denso 21175-0170 key lost; i use tm100 key and tango key no resultat
  15. #15
    Nov 2012
    Default key lost
    lost key z1000
