Hello, need decode Audi Navigation Plus Blaupunkt. 8E0 035 192 B, 7 612 001 013, BNO 881. Eeprom 24c01 attached. Need remove locked time and code. Thank you in advance!
Mariusik (19th March, 2015), masterskay62 (19th March, 2015), Saulius Saulius (19th March, 2015)
How to read fis? I'm newbie on decoding...![]()
Fis 24c32 attached. Code 1498. Just need someone remove "SAFE" "Radio Locked". Thank you. If it not possible to remove, how many hours need wait till I can put code?
try....with your code...?[
ATTACH]305324[/ATTACH]
ilen (19th March, 2015), Mariusik (19th March, 2015), masterskay62 (19th March, 2015), Saulius Saulius (19th March, 2015)
both not working, but anyway thank you.
In my case 1 hour. Code working. Thank you for help.
MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
