Still have problem reading from digiprog 3 clone v4.94 saying plug 51. I think i got color code incorrect. I need help guys i need to do asap thanks in advance. I have TU 2008 if that helps.
Then you need to rewire your Digi cables with the proper colors. I just added correct colors to the ends according to DB25 pinout.
Thanks m8. Ill try opening the cable adapter st51 see if wired correctly.
Does this color code looks good
St51
Red = red/5v
Brown = black/ground
Orange = white or yellow /bkgd
Black = green /reset
You will have to check with a meter to the appropriate pins.
hi every one
please try this file
remaque there is difference name mcu motorola
MC68HC912DC128 BUT I FOUND ONLY MC68HC912DG128.
OTHER THING file must swaped ?try
I checked adapter seems pinout are correct. Keep getting 'error ini' error on digiprog.
today i have try with digiprog3 4.94 the dash was mcu motorola 68hc912dc128. i ust st48... its read ok but digiprog calculate wrong mileage i have press x button it have hive me another moleage but they are wrong ...
after i have enter eeprom to do it manually... in eeprom file the mileage was calculated ok ... when i write the byte... the write complete ok but when i read it again old value re-back again .... so dont waist your time with digprog3 ..enigma will do the job
Hey guys got another version ford expendition 2006. Some help please. Has 93c46 prom but reading 1million somthing milea. Image1470517253.882542.jpgImage1470517263.656421.jpg
Ford with 93c46 hmm never met anything like that all the same post dump and let's see what we can do about it
These have an easy denso algo just like many toyotas. Take the chip off if you have problems reading. You will notice the denso logo on the dial face
- Remember Don't Just Sit There In Boredom, Add to the Forum!!
frankrayk (7th August, 2016), zckariya70 (7th August, 2016)
Same here mate never seen one till now. Does anyone have the pinout for this model. I think hc12
Look the picture:
JammerOne (7th August, 2016)
I know is denso 93c46. But which option do you choose on the TU or digiprog. I dont see any car with option to read a 93c46. Anyone know?
Ok mate, pay attention please:
* Use Digiprog.
* Connect your Digiprog to the power supply.
* Then press ok:
* Put the password (1) and press ok:
* Select Eeprom option:
* Then select "93"
* Select the ?SET TYPE? and choose ?93C46″ (do not select "93c46 x 8")
* Then your digiprog has been set up to read a 93C46 chip. Press ?EEPROM? again and then ?READ?
* There will show you the information on the digiprog III screen when the reading is complete. Now press ?VERIFY? so the information on your screen can agree with the Eeprom.
Next click the ?FILE? and there will show you another sub-menu, you can click ?SAVE? and enter a file name for the information you are saving. Once you entered the file name, your data is safe and the vehicle is now ready to be reprogrammed manually.
Good Luck!
Thanks jombary very big help. Now how to reprogram manually with option. How to write to eprom manually.
