you need to wright Flash first then Eprom after that and you should be fine I had same issue w204 2013 then use filter and change mileage
Hi mates can someone repair my damaged cgw?
thanks a looooot
I also need hel prepairing W204 eeprom and flash. Please help
hi
have a problem done mileage on w204 2007 with dp4 when it turns the dash off, to flip the miles, the dash stayed off, now the problem is the car engine fane stays on when you start and when you close the car, the speedo dont turn back on when you restart the car, until you take the battery off and on then it works?
please check my eprom and flash is ok?
if not can it be repaired ?
think i fixed issue myself with vedimo? will test tomrrow
your eeprom needs fixing, if vediamo doesnt help, report and I will fix your cgw.
hi you are correct, vediamo did not fix, pls fix eprom?
Hi , need cgw w204 repair if possible. Thank you!
can any one repair this eprom and flash from w204, can comuicate with all modules, but engine fan stays on when you start the car and the speedo cluster goes off when you close the car?
any help would be appropriated.
part number is A204 545 62 01
pass in pm
v-diag (11th December, 2018)
hi
thanks , it turned out to be the dash problem, had already taken it out off boot mode with the ffff trick. replaced the dash all is working.
hello
pleas some one fix zgw
here it is
nabilrifi (14th January, 2019)
hello iwrit this file with fvdi and vvdimb ok but when i read agine its same not modfied
