Page 18 of 22 FirstFirst ... 813141516171819202122 LastLast
Results 256 to 270 of 317
  1. #256
    May 2017
    algeria
    How To Repair CGW With avdi ?
  2. #257
    Sep 2012
    Ireland
    Quote Originally Posted by MagicProg View Post
    fix communication first then you can write flash with avdi
  3. #258
    Jun 2017
    Zimbabwe
    Default W212 CGW Repair
    Can you repair this dump for me please ?
    No communication with car after recalibrating odo with FVDI.
    W212 CGW
    THANX IN ADVANCED
  4. #259
    Apr 2019
    Can someboby check these? I did try to fix km with orig Avdi and I think everybody knows here what happened after that....
    I did found eeprom repair instructions from DK but after writing repaired file, I cannot anymore communicate with CGW with Avdi.
  5. #260
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by Moon1 View Post
    Your's optoin is wrong!
    Here ......
    Pass only after press thanks+reputation!
  6. The Following User Says Thank You to brend For This Useful Post:
    Moon1 (6th January, 2020)
  7. #261
    Port Elizabeth
    Hi can someone check and repair w212 zgw my mistake did mileage and now all units no comms
    Thanks in advance
    Shane
  8. #262
    Default Help CGW w204 repair FVDI
    Hello, I need help to repair eeprom cgw. After recalibrating EZS with FVDI, I have no communication with the car, only CGW. engine starts but nothing else works, many times it does not work. Flash and eeprom read fvdi OBD.
  9. #263
    Apr 2013
    Swiss
    I can help you password privately
  10. #264
    Jun 2012
    Default repair CGW W204
    Hello I need help repair eeprom cgw.After recalibrating dash AVDI, have no communication with car. Flash and eeprom read Avdi OBD
    thank you so much
  11. #265
    Jun 2012
    problem solved
    repeat the operation 2 times
    thank you
  12. #266
    Feb 2013
    can someone help with correcting cgw files.
    after fvdi, no communictaion with all ecus, but wipers and headlight working w204 3m25J CGW files attached.
    front sam w204 2012year A2129003314
    Thank you
  13. #267
    Jan 2013
    france
    HI
    I BESOIN D'AIDE POUR
    RÉPARER ZGW W204 APRÈS BLOCK SYNCHRO
    MERCI À TOUS
  14. #268
    Dec 2011
    Hello I need help repair W204 zgw ,after recalibrating dash AVDI
  15. #269
    magneto21's Avatar
    Jul 2016
    here u go..
    your repaired file
    “The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice.”
  16. The Following User Says Thank You to magneto21 For This Useful Post:
    obkaza (7th March, 2021)
  17. #270
    Dec 2011
    Quote Originally Posted by magneto21 View Post
    here u go..
    your repaired file
    All ok , back write eeprom with VVDI Prog !
