Results 1 to 4 of 4
    t77's Avatar
    Poland Lodz
    Default Need EGR off in Vectra C
    Hi DK friends I need EGR off in Vectra C 1.9CDTI ECU Bosch 0281 011 449.. full BDM and Flash and EEPROM
    Feb 2015
    Suraj
    Your file already mod, bad mod
    I correct your dpf off and egr off
    Already you disconnect connector dif,temp sensor and disconnect connector from EGR
  3. The Following User Says Thank You to Prime For This Useful Post:
    t77 (25th March, 2015)
    t77's Avatar
    Poland Lodz
    OK my friend thx for answer ,I will tomorow test the file and post result
    t77's Avatar
    Poland Lodz
    Everything is ok ....no dtc ..worked BIG THX
