old info Code: ( PIN )1111, SN: GM0D3076919085D, Ver: CD 30 MP3, 26.06.2006
write this dump to radio and chek if is good
new info
Code: ( PIN )2871, SN: GM0D3076919085D, Ver: CD 30 MP3, 26.06.2006
lcd have same code as this one
new info
simaservis1108 (26th March, 2015)
You forgot to attach the dump.
Not working
Write unregistered dump to radio.
Display login: 7014
Display vin: W0L0AHL3572086374
I didn't fart,my ass like you so much it just blew you a kiss.
Please tell me what to do in OPCOM to get this working after writing dump...
First step - you must know real CAR PASS (same car login).
Second step - registration unit login (if unit used).
usually DISPLAY pass equal CAR pass.
boukouvalas (7th April, 2020), ilen (26th March, 2015), simaservis1108 (26th March, 2015)
Display VIN not equal to car VIN,so security code is not the same as car,will that be the problem?
Steps after writing unregister dump:
1)OPCOM - EHU
2)Programming
3)Activation Theft Protection
4)Enter display code,in my case 7014
Thank you Zelupentiy,your dump was spot on.
audiopoint (26th March, 2015), boukouvalas (13th April, 2020), ilen (26th March, 2015), jokersat (26th March, 2015), latino (27th March, 2015), madbg (6th February, 2016), things4u2get (2nd April, 2020), zdravo (30th March, 2015)
anyone tried this with martech
I got the first stage code 1111 sn gmos... ver cd 30 mps 26.06.2006
I created an unregister file code 0000
then I selected on martech registering to lcd based on 93c66 grundig opel
load file selected then say this algo requires 2 files.Select first then second file.
then if I select any of the two bin files it gives me an error in the file size
anyone completed this cheers
maybe help............displej.rar
I have same situation.
I bought GID display from scrapyard. Have read the eeprom and later extracted the code.
So I have an Opcom and I divorced the TID and CD30MP3.
Take out TID and put GID in, put radio in.
Got two messages, display sade and radio safe and annoying beep every 5-6 sec.
I divorced GID with its code (extracted from bin).
Then I married GID and CD30MP3.
But still got Radio safe and beep.
So, what to do now?
No Web Links Please !!
Something is not right,there is no option in OpCom to unregister display.
Program original dump to GID,and put original radio dump here.
Program unregistered dump to your radio that you will get here based on your original radio dump.
Activate Radio theft protection with your GID code.
ilen (30th March, 2015)
I believe it isnt right.
Here are original dumps from GID.
https://www.dropbox.com/sh/6e4smqzld...0**0arLBa?dl=0
For radio I will post in few days.
