Hyundai 2009 H1 pin code help
Results 1 to 8 of 8
    12
    Downloads
    9
    Uploads
    Default Hyundai 2009 H1 pin code help
    Hi Guys, I would really appreciate help with a pin code for a Hyundai H1, uses the ID46 chip.
    VIN Number : KMFWBH7RR9U109354
    thank you in advance.
    Dec 2010
    abu dhabi
    7
    Downloads
    188
    Uploads
    your pin code 755104
    DK Veteran sosmecano's Avatar
    Oct 2010
    PROG
    41
    Downloads
    399
    Uploads
    i have done hayundai h1 this week. use ID46 precodade via EFfi or ather tool
    only god can judge me
    12
    Downloads
    9
    Uploads
    Hi, thank you so much, i did have this pin code but I tried to program original keys to H1, it came up with
    "password wrong" , i also used AVDI, that read the pin but could not program keys, key are oem id46.
    May 2013
    125
    Downloads
    3
    Uploads
    Old Pin 755104 New Pin 316457
    Quote Originally Posted by Naren View Post
    12
    Downloads
    9
    Uploads
    Thank you im sure this will work.
    12
    Downloads
    9
    Uploads
    Thank you very much, guys the new pin worked������
    12
    Downloads
    9
    Uploads
    Hi, would you help me with, pin code and key code if possible, for 2006 Hyundai Tucson,
    Old code is 282496, but doesnt work, acess denied.
    Hyundai Tucson 2006
    Vin, KMHJN81VR6U330523
    Kindly let me have old an new pin and if possible key code.
    Thank you
