here you are
here you are
amrif (31st March, 2015)
It is possible to remove this Error wenn something don't Works on the Car??
I mean, I want to put ACC on my Car (Vw Touran 1T3) I have the Hardware from a Passat B7, but the Engine ECU give me this Error:
4332 - Check Coding of ECUS on Powertrain Data Bus
P1647 00 (167) -
I'm thinking that the reason for that its my Engine ECU don't Support ACC...
Yes,that dtc can be deleted from ecu !
Better are to check the coding in engine also gateway !
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
Thank you for asnwer!
I'm trying to understanding what i can do. Coded it's everything (Gateway and Steering Wheel too). But the ACC don't are from factory possible. I'm Trying to retrofiting on the Touran, because they Unit's can communicate between theirselfe, but If ECU Unit "don't knows" what means, than maybe its this the reason for my Error.
I trying to finde someone who can's show on my ECU this funkion. Because on the Passat if I code ACC, and the ACC don't are installed, give me the error that's the Radar are not connected. But If I code it on my Touran without Radar too, my ECU give me this Error:
P1647 00 (167) -
And I read on Motor Talk Forum someone who do that on a Golf VI, they have not from Factory ACC too, and he needed to put this "Information" on the ECU Unit first.
