Results 1 to 11 of 11
    roman_auto's Avatar
    Default Xprog 5.5 how to read St10f280 , any adapter ? Rxd,Txd to Xprog
    Hi all
    I have this ecu PSA, i know the ecu pinout, but i need to know how to connect to the Xprog, do i need any adapter for this ? i have connectotr with wiresto the xprog but i can find the connections : Rxd,Txd on the Xprog , if someone can picture it how to connect to xprog.
    If It Helped Push Thanks
    dominik.m's Avatar
    Jun 2009
    POLAND
    NO need any adapter.
    roman_auto's Avatar
    Yes i have this scheme but in this picture you see there is no Rx or Tx or Pol.4,Reset , so just to connect it like the pins ? regardless to the names ?
    Nov 2012
    Belarus
    Quote Originally Posted by roman_auto View Post
    It's very simple. On your photo xprog pinout rotated in 180'.
    Connection:
    MCU - XPROG
    VCC(5V) - VCC
    PL04 - B4
    RESET - B5
    TxD - B2
    RxD - B3
    GND - GND
  5. The Following 2 Users Say Thank You to ANDRIKSSON For This Useful Post:
    andygtr34 (21st December, 2016), GsmOwar (11th November, 2018)
    Nov 2011
    friend and friend
    Friend not you spend reading with that tool does not work.
    same problem and my solution was piassini + boot mode and it was all ok
    smayer's Avatar
    Jan 2012
    The chinese stick the label upside down
    I have had a bad experience with Fly ....
    roman_auto's Avatar
    Thanks all guys, i did connect it but i dont have function to read just blank and earse, other is in grey, i did read it with Piasini , perfecr
    smayer's Avatar
    Jan 2012
    try click in "new"...., Don?t blame x-prog, must read instruction manual before use!!
  10. #9
    whim's Avatar
    Feb 2011
    i need x prog connection plesea help
    rxd ----->b3
    txd----->b2
    pdx----->?
    rst----->?
    osc----->?
    best regards
  11. #10
    Nov 2014
    bogota colombia
    Hello friends is this micro as it is pinout st10f280 fiat palio
    thanks for your help
  12. #11
    Jun 2012
    Hello friends need pinout st10f280
    magnetti marelli iaw6lp3.07
    peugeot 407
    thank you
