Results 1 to 4 of 4
    Jan 2013
    Default Audi a4 lambda cat
    Hi I need remove lambda cat in audi a4 1.8t
    0261207215
    Only the catalyst is removed or cat&lambda?
    Jan 2012
    Default pass in PM message
    Should be ok, you can disconnect rear02 if U want. Check PM
  4. The Following User Says Thank You to Cymbek For This Useful Post:
    okomar (12th April, 2015)
    Jan 2013
    thanks very much
