Anyone Please!!!
Hi is there anyone that can remove the speed limter from my renault traffic 2 edc15c3 I took 3 different ecu same problem even when i partialy reset ecu I cant get it to go over 90 km any help will do. The first file is original Eprom second is auto reg. for immo PS! the repair file free for all just plug in to car turn ign on wait for immo light to go off and start!
Shane
Anyone Please!!!
Looks like no go on this any advise , what to do!!!!!!
clip programing 10 min work
shanektm450 (11th April, 2015)
clip cant do it would not change it stays on 90km/h even went to nissan to have it checked cant do it goes to adaption but fails all the time
Cheers
Shane
Post the flash limiter is there
shanektm450 (13th April, 2015)
Here is my flash from original ecu see if you can help
Shane
anyone out-there! LOL!!!
I need any flash that will work even if only set to 130km
That flash is bad read, read again and post good ori.
Here is flash from different ECU the van is running with this flash posted above ,it was read with programmer not via obd
It was bad read with ptogrammer many zones full of FF's and should contain data.
Regards,
Serial read is Ok i will look
Please try this,
I think in this file the limiter is at the gear limiters.
392-596Speedlimit.rar
