Results 1 to 2 of 2
    einet's Avatar
    Default Opel 1.3 CDTI 2008 Fap-Off problems
    I bay this car for my wife, but this car is without fap! And have all
    Sensors connected.
    The problem is that the regeneration Lamp ?Resistance lamp? is on blinking
    15 ? 15 days!, then I must make regeneration and make change filter fap over OPCOM!
    To clear the fault!, and this is the problem on the ECU I don?t have errors!!!!
    I try to see on the dump what is wrong but I don?t find more to change!
    Is also possible to deactivate the EGR (to have it closed)?
    How can help me on a good solution FAP ?EGR off?
    einet
    Dec 2013
    Mate reflash your car with new soft from opel online and then you upload your file here.
    That is a only way to now that you will have good flash with good remove DPF and EGR
