Peugeot 207 EGR Off disconnect connector
Nobody????
If Prime file not work, it's all egr dtc off. Pass pm
cawadany (16th April, 2015)
Why everybody puts passwords on their files?Whats the point to have million posts?
The idea of the forums is to help collegues the fastest and easyest way ,i guess.
If just share the file will be time saving for all of us.
Prime wants money. This is a forum, not a market place!
If it was your own car, it would be free. But you have to earn this money.
I do not like freeloaders
Why qualitative solution for the money I paid, but you should get for free.
If you remove the EGR without disconnecting the connector do for free, but the solution to the removal of connectors cost money. You pay for quality.
It's for a my friend's car. I think a forum is made to help and advise each other.No one is obliged to respond and to provide a solution. So if one has to ask for money because it rightly is a particular solution at this point can avoid proposing the solution on the forum.
here EGR OFF disconnect connector
pss in u box
DONT FORGET GIVE THANKS +REP
100% GOOD/TESTED/WORKING Solutions!! ,SwirlFlaps Off,EGR/DPF/NOX/DTC/Throttle Valve/ADBLUE/Lambda/Immo off,(Dyno)ChiptuningFiles,FileService,Remapping,Li censed Winols,
it is tested solution mate
dont forget press thanks and rep+ button
have nice day
