Results 1 to 5 of 5
    moky's Avatar
    Behind you
    Default Sid 206....eeprom corupted help !!!
    hi
    a friend send me a sid206 5WS40862B-T from Ford kuga.he had problem after flash with kess clone ()
    i just connect ecu with bdm 100 ,end of reading I have error checksum...code 1
    I could only read serial E2prom and eeprom is corupted...
    someone can repair it please?
    or full bdm ? siemens 5WS40862B-T 8V41-12A650-CA V4CA J38AC
    attached ori eeprom bdm and read obd flash fonctionnaly
    Jun 2013
    EU
    eeprom is not corrupted, is deleted, full of 00's
  3. The Following User Says Thank You to morgano For This Useful Post:
    moky (11th April, 2015)
    moky's Avatar
    Behind you
    eeprom is out yes... i don't find full bdm ..solution?
    Jun 2013
    EU
    From the numbers you post it seems FORD, maybe with VCM and IDS...
  6. The Following User Says Thank You to morgano For This Useful Post:
    moky (12th April, 2015)
    moky's Avatar
    Behind you
    yes Ford kuga 2.0 tdci 136
