Please help, how to read Segger J-link EDU jtag flasher this Blaupunkt motherboard?
I can connect omap5948, Core ID: 0x0692602F, but flash ID:0xAAAAAAAA.
Should the project file OMAP5948 (.jflash).
Someone can help me?
THX!
THX!
Hi post your serial an p/n here or picture
8M5T 18K931 HD
7 612 300 566
3A056699046694
8075 .... maybe![]()
kappa1 (15th April, 2015), masterskay62 (15th April, 2015)
Yes, 8075.....I can!
but please help how to read external flash!!!!!!!
whay you need external flash
Sometimes not possible to read because flash solder is bad.Unsolder and read...
This units have other problems.
There broken some chips...
Problem are solved. Flash file will not help you.
I didn't fart,my ass like you so much it just blew you a kiss.
And what are these problems? Ive seen several units which didn't start any more, and if I heat up the flash and I power up the unit while the flash is still hot the unit start and run ok. If I remove the power , and apply again when the bga is could the unit is dead again.
I think the flash can be read with jlink but need a proper project. Ive tried to make a project and manage to read only some blocks of flash but the program is disconnecting often. I manage to read and write the flash with a programmer used for jailbreak the PS3, progskeet, but need allot of wires to connect.
radio will not turn on, heating this flash and radio perfect.
reballing this bga flash, one month and the same error.
this flash internal error, not balls error.
i think a solution would be a new flash memory, reading orig dump, replaced flash memory and writing flash data.
i have progskeet programmer, but it must be connected to the A23 address? only addresses A0-A22!
Correct way. Need change 3 chips.
ArnisAAA (18th April, 2017), hrmotorsport (4th July, 2019), pavel635 (14th December, 2015)
clydey (16th April, 2015)
I READING FLASH MEMORY JTAG (JLINK) !!!!![]()
barto41 (28th September, 2019), carradio2001 (27th February, 2023), Faraday (17th April, 2015), foks025 (14th November, 2017), hedi makhlouf (18th November, 2015), kappa1 (20th December, 2015), RadioChiP (17th April, 2015), REZON (20th December, 2015), siti (17th April, 2015), tehnosoftex (17th April, 2015), Thinner (28th August, 2015), tom222 (8th December, 2020), yahia1908 (25th February, 2020)
