Page 1 of 9 123456 ... LastLast
Results 1 to 15 of 123
    Default Swap octivia cluster nec
    Please advice how to swap, I try by copy immo data with avdi but didn't working, not start and safe mode on.
    I forgot to push reset button in The end, maybe This is why didn't working?
    This is 2011 skoda octivia
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    What is wrong with original cluster?
    Screen lcd
    Try to reset cluster. You manually copy all fields? Avdi show 7 or 12 cs byte?
    Yes manually, 7 bytes
    The eeprom is different 24c32 and original is 24c64
    Faraday's Avatar
    May 2012
    The dark side of the moon
    With smok X-can you can transfer security block by obd
    Well I got avdi
    Then it will not work. Most 2009- have 12byte not 7 as i say here many times. There is no option for transfer whole immodata?
  10. The Following User Says Thank You to autofan1965 For This Useful Post:
    obdsystems (19th April, 2015)
  11. #10
    If I swap eeprom?
  12. #11
    yugo45's Avatar
    Quote Originally Posted by totalkey View Post
    Immo block should be same size of 32 and 64,I know X-Dahs has same , never use AVDI on this , but I think it should be same size file.
    So just open it in Hex editor and see , if is same size . just write whole immo block to new cluster, and it will be plug and play.
    I hope you did back up for ABS, before you install new cluster in car. otherwise you will lost ABS coding.
    If is not same size post Immo block here to see what can be done.
  13. The Following 2 Users Say Thank You to yugo45 For This Useful Post:
    totalkey (17th April, 2015), ttzag (17th April, 2015)
  14. #12
    yugo45's Avatar
    Quote Originally Posted by autofan1965 View Post
    ALL NEC clusters has same data . That was micrinas dahs had only 7 bytes.
  15. The Following User Says Thank You to yugo45 For This Useful Post:
    Faraday (17th April, 2015)
  16. #13
    Quote Originally Posted by yugo45 View Post
    No I didn't backup ABS. And now it lost, you have coding maybe?
    I will try to write to whole file
  17. #14
    yugo45's Avatar
    Avdi have Coding builder , so you can built coding.
    Make sure you do only Immo block , not whole eeprom.
  18. #15
    I see, can I upload Both and You will Do it for me?
    I don't know How to find the immo part in file.
