Page 7 of 9 FirstFirst ... 23456789 LastLast
Results 91 to 105 of 123
  1. #91
    Apr 2011
    in lebanon
    Hello.
    Dear friend,if the original old ezs present,so just found who have xprog-m in your area, and read the flash of original EZS & after write it in the new ezs by xprog-m, or you can buy xprog-m it is not expensive. let us if any new...
  2. #92
    Quote Originally Posted by haroutioun View Post
    Hello.
    I don't have old esl
  3. #93
    Apr 2011
    in lebanon
    Hello.
    OK friend did you try adapt by avdi from immo parts adaptation?
  4. #94
    When trying to adapted and put ecu file it doesn't success to access ezs and when I try with ezs dump it can't access to ecu, I have gear box dtc - locked
  5. #95
    Hello.
    Yes, But ezs data and ecu are different I think, and I can't modified the ezs data
  6. #96
    Also maybe It's different software in new ESL
  7. #97
    also for some reason i cant update ecu config data by obd with avdi
  8. #98
    Last question please, if I bring pair ecu and ezs it Will fix the problem?
  9. #99
    Apr 2011
    in lebanon
    Hello.
    sorry i am repaying late cause i have a lot costumers in my garage.
    1) just let us to know the ezs not in your garage change + adapted?
    2) so you never can re get the original ezs?
    3) if you can get xprog-m after i can send to you full dump to write it in ezs,& after you can unlock your remote key by your eeprom dump and after re adapt all by avdi.
    4) or you must get new used ezs to done...
  10. The Following User Says Thank You to haroutioun For This Useful Post:
    totalkey (20th April, 2015)
  11. #100
    Hello.
    No I don't have original ezs and not have xprog, I told Costumer to buy paired ecu and ezs And I will adoption the gear box
  12. #101
    Apr 2011
    in lebanon
    Hello.
    but your loaded dumps show me your engine ecu adapted to ezs. cause i see the (6 cs bytes) + the pin code of ecu in the ezs for that the car start,but we need next (6 cs bytes) which they are in the ezs flash and in gearbox, those which must adapt to done the release of safe.
  13. #102
    Hello.
    Sorry, also ezs and esl and gear got 12 bytes?
  14. #103
    Apr 2011
    in lebanon
    Hello.
    the ezs it mean ezl,yes there is 12 bytes look the photo
  15. #104
    Hello.
    Something strange in this car, I can't see Any vin in all models, so if I bring new set ecu and ESL I can adoption with avdi?
    Avdi will change 12 bytes in gear box?
  16. #105
    Vin is inside esl and ecu. MMI take vin from esl too.
