Results 1 to 12 of 12
    Default Bmw fault codes with mileage
    Had a e60 to workshop this week. Have done odometer and cas before. can still read old mileage from faultcodes!
    From what location do faultcodes read mileage?
    Mar 2013
    Quote Originally Posted by Speedofix View Post
    Which tool are you using to read fault codes ?
    Auto com... have done this one year ago.
    Mar 2013
    What are the faults that are stored ,with mileage readings ,there are many units in these store mileage but you would need explorer to sort them out.
    If disconnect something on engine to make fault. I got fault code with old Milage.
    Mario3's Avatar
    Dec 2014
    probably from engine ecu, make manually mileage in eeprom and try again
    Need full BDM read out or it only stored in eeprom ?
    Mario3's Avatar
    Dec 2014
    eeprom only, best desolder and read with programmer
    Do you know software that can calculate this ?
    Mario3's Avatar
    Dec 2014
    Post dump here and someone will do it for you
    Hi, clear the faultscodes with ISTA.......??? is better.......
    M Coder ist good for BMW: CAS, ECU, Gear ECU, x Gear ECU, RPA, Battery Registery, Battrery History...
    vrsc
