i am also having an issue with my A1 Cable, here is a picture of the board, all looks ok to me but i need to check it with a meter
i had same issue - i just replaced the resistors and after tool was working ok.
Chiptuning fanatic - FILE SERVICE 24/7! Chiptuning / Dpf off / Egr off / DTC off / etc.
Bapro 4x4 dyno + SP6
Flex / X17, Autotuner, Bflash, NewGenius, FGTech, HPTuners, BitBox, PCM Flash
I never put pin 16 extra 12 v it is no nesesary
Enviado desde mi iPhone utilizando Tapatalk
mine do not work, even though i bought a whole repair kit from code card and repair mine A1 but still, here is an image of mine
http://www.mediafire.com/download/1d...bk21ar7/A1.rar
Hello after repair faults you used carprog 7.28 is a good
https://mega.nz/#!D88AwBqK!4ySZzeMxk...hLGq9xbPwQP7ak
forummoto:
Did you replaced MCP as well in side of A1adapter?and did you checked that +12v common issue?
Yes buddy, i did replaced the MCP, i bought all set from codecard. i did also checked for 12+ on that mofet which gives the volts, so i see no need to connect wire from pin 16 to it
Using this version does not have anything changed, it is the lib file and the dumb in the atmel chip that is what remain the same and give the same interface as whatever version you re using. So i do not buy the idea of 7.28 stuffOpel CAN ECU problem.jpg
ok,this is tested?
is there any extra item activated in 8.21 compared to 4.74 ?
