Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 39
  1. #16
    Nov 2009
    i am also having an issue with my A1 Cable, here is a picture of the board, all looks ok to me but i need to check it with a meter
  2. #17
    Dec 2013
    R1 and R4 are wrong
    Quote Originally Posted by ash08 View Post
    mbtun's Avatar
    May 2012
    Europe
    i had same issue - i just replaced the resistors and after tool was working ok.
    Chiptuning fanatic - FILE SERVICE 24/7! Chiptuning / Dpf off / Egr off / DTC off / etc.
    Bapro 4x4 dyno + SP6
    Flex / X17, Autotuner, Bflash, NewGenius, FGTech, HPTuners, BitBox, PCM Flash
  4. #19
    Dec 2013
    I never put pin 16 extra 12 v it is no nesesary
    Enviado desde mi iPhone utilizando Tapatalk
  5. #20
    May 2010
    mine do not work, even though i bought a whole repair kit from code card and repair mine A1 but still, here is an image of mine
    http://www.mediafire.com/download/1d...bk21ar7/A1.rar
  6. #21
    Aug 2009
    Hello after repair faults you used carprog 7.28 is a good
    https://mega.nz/#!D88AwBqK!4ySZzeMxk...hLGq9xbPwQP7ak
  7. #22
    Apr 2014
    forummoto:
    Did you replaced MCP as well in side of A1adapter?and did you checked that +12v common issue?
  8. #23
    May 2010
    Yes buddy, i did replaced the MCP, i bought all set from codecard. i did also checked for 12+ on that mofet which gives the volts, so i see no need to connect wire from pin 16 to it
  9. #24
    Jun 2015
    Quote Originally Posted by forumoto View Post
    Strange that the repair kit didn't fix your issue..maybe it's one of the resistor like the other guy said?
  10. #25
    May 2010
    Quote Originally Posted by grostoto View Post
    Using this version does not have anything changed, it is the lib file and the dumb in the atmel chip that is what remain the same and give the same interface as whatever version you re using. So i do not buy the idea of 7.28 stuffOpel CAN ECU problem.jpg
  11. #26
    Apr 2016
    ok,this is tested?
  12. #27
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Mine works fine but my mates don't even after hw repair so he bought another A1 from China and all is good now so maybe a bad pcb
  13. #28
    yellowstilo's Avatar
    Nov 2009
    Quote Originally Posted by znoki View Post
    Sorry, I don't understand, could you please explain!
    your fake version "7.28" is the old 4.01 version, better upgrade to version 4.74 for more activated functions......
  14. #29
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by yellowstilo View Post
    Better to upgrade to 8.21 latest for clones
  15. #30
    Nov 2009
    is there any extra item activated in 8.21 compared to 4.74 ?
