Page 1 of 3 123 LastLast
Results 1 to 15 of 39
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Default Carprog China clone - Both K and CAN not working - A1 adapter changed everything
    Hello guys,
    Could anyone suggest anything that I should try out to repair Carprog.
    Tried programming Renault Laguna and Megane cards,no communication with the ECU both cars.
    A1 adapter changed everything.
    Regards,
    Sima
    Nov 2013
    Lietuva
    how about self test with a9 adapter ? is all ok?
    OPEL / SAAB EDC15M * PSG16 * EDC16 * EDC17 * DENSO * ACDELCO cloning / programming / resetting
    antonypaul's Avatar
    Jun 2010
    Did you test all components are solder good or need make solder again China made need to solder again or try with forum post
    http://www.digital-kaos.co.uk/forums...Carprog+repair
    We live and work in a changing world. New laws are introduced that lead to the introduction of new policies.
    Faraday's Avatar
    May 2012
    The dark side of the moon
    What version of Carprog? if 4.01 forget CAN functions
  5. The Following User Says Thank You to Faraday For This Useful Post:
    hbfj (11th March, 2017)
  6. #5
    Aug 2013
    Serbia,Belgrade
    4.01 yes.
    Should I flash it with other firmware?
  7. #6
    Aug 2013
    Serbia,Belgrade
    Does anyone have 4.74 firmware files?
  8. #7
    lkjubaking's Avatar
    Feb 2013
    Serbia
    Default pozdrav
    Hi friend
    this is tested solution for 4.74
  9. The Following 9 Users Say Thank You to lkjubaking For This Useful Post:
    azare (14th December, 2016), davidjona (19th February, 2019), dvdpgn (5th February, 2017), jnoroeste (2nd August, 2015), madbg (5th December, 2016), pablodelhierro (17th January, 2016), remhonda (21st August, 2015), rumensivanov (18th June, 2016), teuton (19th May, 2015)
  10. #8
    Faraday's Avatar
    May 2012
    I had to send mine to fix it. I could not find any update files etc.
    4.74 is different serial I think that you will have to chenge at88 content (different LIB)
  11. #9
    Faraday's Avatar
    May 2012
    Quote Originally Posted by lkjubaking View Post
    Hi friend
    Will this change sn in carprog I don't think so.
  12. #10
    Feb 2011
    Split
    I buy 3 carprog. Only on one A1 works. And seller sent me more one. Thats 4, one works!
  13. #11
    lkjubaking's Avatar
    Feb 2013
    Serbia
    with H-tag and 5x100_OHM_jTAG.jpg on LPT and at91sam7s256 -sn-m61.bin file you can upgrade carprog to version 4.74
    this work sure with this soft and lib file
  14. The Following 9 Users Say Thank You to lkjubaking For This Useful Post:
    auto diag (4th June, 2015), jnoroeste (2nd August, 2015), madbg (5th December, 2016), mohamedkey (3rd August, 2015), rumensivanov (18th June, 2016), thayer201 (15th November, 2016), ttk1989 (11th December, 2018), zyjekrc51 (26th August, 2015)
  15. #12
    znoki's Avatar
    Dec 2010
    land of plenty
    Hi Guys,
    I have a chinese carprog clone V7.28. I tested it on Opels, K-line functions working well.
    But should I update to 4.74? Is it better? (I know 7.28 is just a bulls..t number, truly which version is equal to 7.28?)
    If I know correctly, no chance to use emulator function, mainly Volvo Dash CAN emulator?
    Cheers!
    Cheers!
    even though 2 legs from 8 are not bonded, a spider is a still spider (93c86)
  16. #13
    Nov 2012
    Croatia
    For exp. if you have hw 4.01 ,you can use any version of sofware but open only 4.01 option
  17. #14
    znoki's Avatar
    Dec 2010
    land of plenty
    Sorry, I don't understand, could you please explain!
  18. #15
    Apr 2013
    Check the items on the board A1.
  19. The Following User Says Thank You to 2xded For This Useful Post:
    Kayhan 17# (18th February, 2020)
